Nikhil
Andy1GP said:Diesel Yoda has spokenNico you must grace us with your presence so we can test all the E46 diesels with one another...
Yes please :rollsmile:
anton-sa said:when you start talking different injectors and whatnot things start becomeing expensive. interesting factoid. auto e39's before mid 2000 used injectors that cost over 5k each at agents. auto mid 2000 and on use injector that cost around 3k each. manual e39 early 2000 on use injectors that also cost 3k each.
this is not heresay or a story. i was sitting in the parts dept at autoatlantic and craig there showed me on the system where it describes this and the priceing etc...
can the diesel yoda's explain this ?
Nikhil said:anton-sa said:when you start talking different injectors and whatnot things start becomeing expensive. interesting factoid. auto e39's before mid 2000 used injectors that cost over 5k each at agents. auto mid 2000 and on use injector that cost around 3k each. manual e39 early 2000 on use injectors that also cost 3k each.
Unless the physical part numbers from Bosch are different I highly doubt that they are actually different, Bmw have been known to do some weird shit in terms of price. I remember comparing a brake booster for an E36 M3 and an older generation 540i or M5 cant remember now, even tho the parts were identical with manufacturer part numbers the bmw part numbers differed and resulted in about a R2500 difference in price with the E36 M3 “Part” being more expensive. So I seriously doubt its different injectors maybe different bmw part numbers but the actual manufacturer part number is the same. Bmw are known to pull prices out there ass anyway so I wouldn’t really read much into a price difference, I think they determine pricing by saying oh we think owners of the 540i should pay more for parts than 530i owners.
Lol yep it is steep. Diesel electric will probably cheaper tho for most Bosch itemsanton-sa said:Nikhil said:anton-sa said:when you start talking different injectors and whatnot things start becomeing expensive. interesting factoid. auto e39's before mid 2000 used injectors that cost over 5k each at agents. auto mid 2000 and on use injector that cost around 3k each. manual e39 early 2000 on use injectors that also cost 3k each.
+1 - I think you are correct. most likely.
but still even at 3.2k to be exact. its still 19k for the @#$$@ers
DieselFan said:Nice. I'm going to be using liquimoly oil, with liquimoly ceratec, liquid moly gear protect and another liquimoly gearbox oil additive. I will be using half ceratec and half gear protect in the gearbox and Diff. Not all of the above are suitable for auto boxes.
you wishDieselFan said:And Nikhil is being kind enough to fly down with that intercooler for me. Thanks nikhil!
so not giving to ZF to service anymore...?Nikhil said:
Im most likely going to get ZF to do it but just charge me for labour as I want to supply the oil also most likely 10liters of oil so that the box can be flushed and refilled:=):sash said:so not giving to ZF to service anymore...?Nikhil said:
ah ok, let me know how it goes, i am yet to do my thermostat as i cannot find a decent torque wrench that starts from 10nmNikhil said:Im most likely going to get ZF to do it but just charge me for labour as I want to supply the oil also most likely 10liters of oil so that the box can be flushed and refilled:=):
sash said:ah ok, let me know how it goes, i am yet to do my thermostat as i cannot find a decent torque wrench that starts from 10nmNikhil said:Im most likely going to get ZF to do it but just charge me for labour as I want to supply the oil also most likely 10liters of oil so that the box can be flushed and refilled:=):
