zabbo said:
evnmopwr said:
Why is there what looks like an old wooden steering wheel just lying on the floor in the corner?
Lol. Thts n old beetle steering. Its not wooden. Its hard foam. The vinyl is off.. Pretty useless steering. My pitbul plays with it. Hahah
Another issue.
Propshaft. Lol
325i diff cups are all differnt. So cannot use the 330i prop shaft as is
325i prop has the splin on the first half of prop
330i has the spline is on the second half of prop
Noone wants to attempt to remove and swop the ujoints. So looks like im installing the 330i diff too.
So my next question, if i choose not to install the rear brakes frmthe 330, will the side shafts fit my brake hubs? Or are the splines differnt
If not, will install the entire hub with trailing arms and complete the brake upgrade to 330i.
Will post up more as i do that. Too damn hotto be working outside today
Also,the Side shafts are Thin, 1 sized and the 330s are Thin in the centre and thicker on the sides.
The bolt Gaps that connect to the Diff on 330 are wider apart on there than on the 325. so 325 shafts i cannot use
Anyone has the Left rear side shaft for a 330i they want to sell??
Thats the one thats is broken. :'(
As promised, This was the plug thats Different on engine loom
325s plug ( 2 Round Connectors )
330s plug ( 2 Flat connectors )
Connected the 325s plug to the 330s engine loom
Some images thats making want to driver this car even more
Test fitted the Mtech bumper
Stiffner is damaged so alignment on the passenger side is not perfect
