hi guys
Quick update..
Was out of town for a while so did not get much done
upon returning, Battery light would come on and off... Checked the charge with load using the hidden test feature on cluster and it was reading 11.9V with lights, radio etc etc on..
Was afraid when i found out its a Valeo Alternator i had thinking the Regulator was Soldered in place.
Turns out the Valeo i had could have the Regulator replaced
Valeo alternator P/N SG12B026
After much hunting, speaking to LOTS of stores who all told me, "We never in history ever stocked this part" ...
Ziyaad at AutoMagneto arranged me a New Regulator.. took a day for the most for him to get it.
MobileTron Regulator P/N reg0025
VR-PR2206
Costed only R285 rand.
I did not remove the Alternator during the replacement and did not get pictures of the process as i was rushing to complete as i needed to help the SO with my Kid.
Simply Disconnected the Negative terminal on battery
Removed the airbox ( 10mm Socket used for 2 bolts PLUS screw driver for MAF Clamp )
Removed the power line to alternator ( 17mm Socket used if i remember correctly )
Disconnected the Duct to alternator
removed the Plastic Cover ( 7mm Small tube socket needed 2xbolts )
Removed the Regulator ( 7mm Small tube socket needed 3xbolts )
Old Regulator
New Vs Old
When installing the new Regulator, it has a Black Round section (as seen in image)
The New Regulator comes with 2, the one on is actually holding the Brushes back
DO NOT REMOVE IT...
Install the regulator as is and tighten the bolts.
Once its in place, pull the Round black cover off and the Brushes pop out and make contact to the Alternator shaft
Now you use the second black cover to Slide over again
This image Shows the First Cap that is on the Regulator
the arrow points to the Brushes being pushed back by this cap
The second cap has the Circled section open so just a cover
Correct and Steady 14.2V
Funny enough, my car actually idles million times better and it has not Picked up the Misfire i was fighting to resolve ever since...:smilebounce:
This weekend is DENT REMOVAL weekend
Will lay on some Primer to the sections with dents i remove.
My timeline will be stretched out abit. Due to My other project Needing to be completed, 1975 VW passat LS Coupe, they will be sharing time ...
Thanks for looking guys
