The 318i's clutch was pretty worn and quite stiff when I got it. After I replaced it it was super light. As time went on it got a bit heavier, although it doesn't seem to be getting any heavier since. Thursday I was doing a lot of stop, go, stop, go, ect. and yesterday my left leg was a tiny bit stiff :uhoh:
Maybe a fluid replace is the answer.
Don't think I've mentioned this, but the rear left window's rubber was loose and if you take the window down and then back up, the rubber would end up outside the window. The guy I bought the car from said I needed to replace it... BMW wanted R1600 something for a new rubber :spit:.
So this morning I pushed the rubber back in it's place, although I couldn't get it perfect. I then went to town to find new setscrews for the wheels covers and I found Allan key replacements for like 60c (And BMW wanted R24.00 each and I would have had to wait 3 weeks :spit
. I ended up replacing all the screws in all the wheels. So now all the covers are fitted and the car looks awesome. I thought my brother was green before... you should see him now
I haven't taken picks yet, sorry :mmm:
I then went to PG Auto Glass and explained that BMW wanted a million for new a window rubber and the guy said they will take a look. Now the rubber is seated properly and I'm leaving the window close so the rubber would set back to the shape it should be. It's difficult to explain what exactly the problem was, but it wasn't anything major.
Something else I noticed today was that there is a lot of heat under the dash where my feet are. I have no idea what it could be as I haven't taken a look yet. All I wanted to do when I got home was take a cold shower as it was very hot today. Although the 540's aricon seems to work fine, a stronger fan would have made it much better. :mmm:
All in all the car is not perfect, but that's the case with any second hand car and I knew there would be things that need work. :thumb:
If all goes to plan then I'll wash and clean the car from front to back tomorrow morning after which I'll take some proper picks inside and out. :thumbsup::thumbsup:
Then I need to see if I can do something about the 318's exhaust. The last people to have worked on the car (2 years ago) did not tighten one of the nuts that hold the exhaust to the manifold and it's now leaking quite bad. I thought it was the engine as I could not find anything wrong with the exhaust. But when it was on the lift at Speedy the guy said it was indeed the exhaust and that it is cracked. I asked for a torchlight and had a look myself and found that the one nut wasn't even near tightened (No cracks in sight :bs
. I also need to service my mom's car and get it a new battery. And I have to finish 2 of my projects this coming week as we are going on Training the 27th (Flying up to Jo'Burg).
So much to do.............
