Witch progress
Crash_Nemesis
Hmmm. WE best have a look at that rust and clean it up. LZ? What can be done on this? How much to fix? Maybe we add that to the list of things to fix if it isn't too bad?
zaleonardz
Strip everything around it, but i mean everything, have it pressure cleaned.
I will ask my panel beater to do grind the rust, put some rust inhibitor, paint.
If you do the stripping/preperation, and I can do it in a day, no charge :)
If I have to do the stripping car will be here for a month, we are really full,
Its the stripping/reassembly that takes a lot of time, bring me a bare engine bay, and i can sort out that rust, its nothing.
Ralf*
Speedway Motorsport can throw in any wheel alignment, wheel balancing and/or exhaust welding if required (labour items}
Thunder
Okay. I'll get everything out on Monday as there are still a few stuff we left when we pulled the motor. Then I can take some proper pictures.
LZ by everything what can be left besides the steering column just to ensure that the car can turn.
Sent from my GT-I9300
Thunder
zaleonardz@DentDocVPS said:
Let me put it this way, everything you dont want overspray on :)
But mainly the grease/oil residue.
So I take it all the heatshielding as well?
Thunder
Might just be a refitting of the exhaust. :fencelook:
TOOFAST MP
Well done guys i think its good you guys in a position to help are assisting with the car helping him out its great, remember the wheel turns and when you do good for others it comes back when you least expect it.
Well vo:
zaleonardz
Look, we can mask everything, but the harder you work, the neater the job, thats how it is with everything..
But pref heatshields
Rubber grommets on firewalls ect, we can mask the ABS ect.
Everything off of the chassis legs at the very least., brake pipes ect, suspension say bars,
Problem is around these parts, is where you have the tiny grease/grime deposits, and thats enough to ruin the paint work, even if it is only base coat black...
Thus, were we need to repair, everything off/out and degreased...
Thunder
Okay will strip as far as I can, then I will post some pics and you can say if there is something else you think should be out. :thumbs:
Thunder
Well vo:
Well just to say this wasn`t expected at all.
Still feels a bit like a huge dream as I never thought that my Witch would ever start again as a whole, never the less be fixed and maybe even a little upgraded.
Thunder
So we stripped out most of the parts(hope it's enough)
Pictures of the rust.
We scraped of and out all the loose rust and found it bigger than I initially thought. But it looks like only a support bracket, don't know how serious it is though.
Will post some more pics later. Took some with the camera.
Crash_Nemesis
LZ is currently dead... He has really bad Flu, so I guess you will only be able to take the car past him in the next week or so.
Hopefully he will be able to look at the pics in the interim and get back to you on PM.
zaleonardz
Yea. I died... pretty much
Unless you folks want to hear my donald duck meets Al Pachino voice, its actually pretty kewl.. in a wierd froggy sort of way.
I will drop the pics past my panel beater, and here what he says...
It does not look good though...
