MiteshN
Hi all.
So I am a bit confused and would like to ask those with much more experience and insights to weigh in here.
My F30 320i sportline with an N20 engine is smoking on cold start up if the car has not been started for a day or 2. The smoke clears almost immediately and is not there under acceleration or when the car is warm or of the car has not been left standing for a day or 2.
I have been advised to start with replacing the tappet cover and PCV valve. However I have also read from multiple forums that the problem might actually be the oil feeder line to the turbo. I am not sure which one to look into and sort out first and which should be the priority. Looking at parts I believe parts for both with all gaskets etc and other recommended parts to do at the same time amount to approximately R14k and the. It’s the labour which is 2 separate jobs so would amount to a bit in total. I can plan for one in the next couple months and the other in another 6 - 8 months.
Also not sure if I would need to do both jobs or just 1 and which one. So any advice on which one is the best to do first and most probably sort out the smoking issue?
Also any advice or recommendations on a reputable and reasonable place in the Johannesburg South or surrounding areas to have it done if I purchase parts directly from BMW dealership?
