Dishen said:None of the Sasol garages in Durban stock 10PPM :thumbdo:
CliftonH said:I filled a tank and the consumption seems to be a little higher. I filled bp today and consumption dropped. But I will keep using Sasol to help clean the engine and make it last longer.
First, I want to concentrate on the loss of the sulfur and why this is important to you. Sulfur is an Extreme Pressure (EP) lubricant. It is regularly added to lubricating oils and greases to increase the lubricity and to raise the amount of pressure that the lubricant can handle before the lubricating molecular barrier begins to break down. Sulfur has always been a vitally important factor in providing lubrication to diesel engine fuel pumps, fuel injectors, and to a lesser degree engine valves.
In 1993 the EPA forced the reduction of sulfur in on-highway diesel fuels from an unlimited amount (typically .5% to 1% (5,000 to 10,000 ppm), although occasionally as high as 2% (20,000 ppm)) to a maximum of 500 ppm (.05%). At that time, there was a 12 to 24 month period where significant problems with failures of some metallic fuel system components such as pumps and injectors due to the dramatic lowering of lubricity and with seals, gaskets, and other rubber or synthetic components due to the reduction of elasticity caused by removing the sulfur. It was nearly two years before changes were completed in the new engines that ameliorated those problems and repairs made to older engines that controlled these problems.
During this period many fleets and individual operators began additizing their fuels to restore this lubricity and elasticity.
The reduction now being made takes on-highway diesel from less than 500 ppm to less than 15 ppm, which for all practical purposes eliminates sulfur as a lubricant in the fuel.
DieselFan said:CliftonH said:I filled a tank and the consumption seems to be a little higher. I filled bp today and consumption dropped. But I will keep using Sasol to help clean the engine and make it last longer.
To be honest I don't think its going to make a huge difference. My 330d has done great with 50ppm. If I were to use 10ppm I would have a bottle of additives to help with lubricity.
Source: LINK
ChefDJ said:No increase in smoke :fencelook:
DieselFan said:ChefDJ said:No increase in smoke :fencelook:
Nah was asking Armstrong if he had more smoke adding the 2 stroke oil.
