Project E46 330i Touring
evnmopwr
After selling my E46 320i ( Was jst tooooo LAZY!!! for me ), and scouting for the past Few months for a 325i touring Project, I found one with Lots needed but LOTS of potential
its a 2001 E46 325i touring, has about 280k on the clock, Full service history, Spare keys, sunroof, Pdc etc etc etc
The PO Smashed the Car, and it sat as it was for 6 months. When i went to look at the car, 2 weeks ago, Amazingly, she fired right up and Even moved in that sad, crashed state..
When i collected:
At home:
More to follow.. FULL service, new tires, Engine mounts, radiator etc etc etc
Thanks for looking
Coisman
Administrator
How difficult to do (if at all possible) a Facelift transplant on it?
Bonnet, fenders, bumper, grills, headlights?
evnmopwr
The car was pretty much straight
These are the ONLY real problems on the chassis but are repairable as it is. No chassis straightening needed...
Also, a dent on the passenger Rear door and Quarter panel
The tear-down:
The Bumper arm ( No idea what to call it ) its where the Bumper stiffener connects to
After i straightened it Up
Welded in place
I have since neatend this up and sprayed, Will post updated image of it later
This Part is where the fender runs onto and the Radiator Craddle too
I cut this off the Donar car i bought for the front panels
Test Fit
Its since been welded in place
not difficult at all... exactly as you mentioned
The Damaged Bits attached to Engine
Both belts Are Dead, Water pump pulley, Thermostat housing
The Parts ( All bought by Goldwagen )
Best German aftermarket parts ( My experience ) besides the sensors and filters, that i got at agents and the Oil
OIL, Oil filter, Spark plugs, two engine mounts, Radiator, Idler Pully, Aircon Pully, two new belts, Antifreeze, New tires, Cabin Filter, air filter, waterpump, WP Pulley, Thermostat, blah blah blah
Pulled the car into Garage to have the Engine mounts and Stuff fitted
Coisman
Administrator
So do it :thumbs:
evnmopwr
So do it :thumbs:
lol I had a choice, 12grand for Just the Front facelift panels or 5grand for a 2001 donar car with everything minus Engine, gearbox, Prop and diff...
SO YES, STILL HAVE A FEW SPARES TO SELL FROM IT!!!! DASH,AIRBAGS,CLUSTER ETC ETC ETC ETC
I chose the donar .. lol
evnmopwr
sash said:
great project and quick progress too :rollsmile:.
I got her running in Just over a week, :clapper:
Lotsa photos, im narrowing down the ones that i want to load up
:chef:
evnmopwr
Test Fitted the Craddle to check that the Arms that the Stiffener mount to are straight
Bonnet and Craddle install
Lines up nicely and the catch is 100% accurate
Stiffener and fenders added and Lined up, gapping checked and measured
Results after that Evenings work, Everythign Pretty much in place
After assembly
The beading and All has been added so far...
Trying to get the car ready ASAP to go through roadworthy. have few things to get sorted before this weekend... will post latest images with beading and all on tomorrow
sash
:chef:
:tiptoe:
And here i thought these pics were over a period of weeks..., great stuff
AndreB320i
Hehe, at least with all the front bits off it's sooo easy replacing PS pump, water pump, belts and pulleys.
Did them all on my e46 in the cramped space available.
tman
Wow, Good for you for taking on this huge project!
Loving the pics, keep 'em coming!
evnmopwr
So the car is Mobile...
Has some Drivability issues when idle so been Looking into that for that Past few weeks but its daily driven..
Issue:
At idle, Low revs of about 650-700 RPM, The Car will ping Between 1000 - 3000rpm but still has all the power
when the Idle decides to correct itself to about 800-900rpm, There is No Ping, But car is lazy as hell!!!
nothing on the ECU but Misfire codes on 1, 4 and 6cyl.
It only Misfires when idled for like 5min.
Revs are bouncy, Plugs are Carbon fowled and Smells of fuel
Thinking maybe the Airflow meter??
I put a hold on the rest of the Cosmetic work for now to focus on the driving issue but have few tests planned for this weekend and see if i can narrow it down
this is what she looks like currently
Also have a Set of Coilovers on order, Def needs some Low...
Ordered this off Aliexpress, hopefully it fits neatly, Attaches to the Original bumper
Will Attache some Interior Shots once i get the car cleaned And will Magnify the rest of the Cosmetic's that needs attention
Thanks for all the kind words
:ty:
