Crash_Nemesis
OK. Update time...
Cylinder head is done. 3 Angle Valve cut on the valve seats has been complete. What this does is make the passageway for the air coming into the cylinder head more narrow, thus accelerating the air and giving great performance. The Vac Motorsport Valves with Single Groove cotters are also finally in. I bought them last year September... Finally got these bad boys in. They have a single groove at the top, which most if not all race cars have, apparently this is better than the usual 3 small grooves most cars have. Not sure why... The valves are inconel and can handle some crazy abuse. Here is a link below for you to check out the valves... they have come down nicely in price. Wish I bought them now instead of a year ago when they were almost double the price. Stupid me.
http://store.vacmotorsports.com/vac---s54-high-performance-valve-kit-24-6mm-valve-stem-p1343.aspx
Here is a picture of the single groove -
Onto the block.
It has been dipped and all red paint from Matt's previous build has been stripped off. The cylinders have all been re honed to the CP pistons spec sheet. See below
The block is done, the first coat of paint goes on tonight, and we start re assembly tomorrow and this weekend.
Here is a pic of the block and the cylinders after being re honed.
Yes... those are ARP L19 head studs/bolts connected to the block. Those bad boys can hold down 1400hp before the block and head start to separate.
Will update more this weekend!!!
Thanks Peter for the help!
Onto the block.
