Rowen@CleanCarTechnologies said:Well done. Keen to share any logs?
+1firaz said:I've watched this video about 10 times already.
That acceleration is just insane.
Sent from my HTC One mini 2 using Tapatalk
Kish2604@TheFanatics said:Well done on the power!!!
Not to sound like a wet blanket though I would like to point out a few things, most important is if you don't want to play knock knock jokes then stick better fuel in to the car if you going to put a single turbo at 20psi! Secondly whoever suggested that you try map 7 with 23psi on a standard tmap needs to be spanked! The stock tmap range ends at 21psi and targeting that boost beyond that will end up in the dme running "blind"...
All the best with the final details and tuning of the build!
Johnny135i said:Thanks for the update!
I'm watching this thread with great interest as this is also where I'm heading.just with a Pure turbo:rollsmile:
Good luck bud:cartel:
Rowen@CleanCarTechnologies said:Nice update and glad you enjoying the build journey.
Let me know what clutch you considering, my SPEC 3 last 6 months![]()
Chucky said:Great build, looks super fun and scary at the same time.:coolShake:
am i the only one that does not understand half of the things spoken here...
Knock/ing flase knocking knock knock etc, Spec 2+/Spec 3 Clutch, map 1-7 etc?![]()
KrS24 said:Here is the rule of thumb with this ST build map selection. (Assuming 1 x 10ghp nozzle)
Map 1 (15 Psi) can be used on pump 95 : +400whp
Map 2 (17 Psi) 95 plus >40% Meth : 500whp
Map 5 (20 Psi) 95, >=60% Meth and >20% Eth, a can of NF wont hurt either : +-570whp ( need a stronger HPFP to push higher numbers)
Map 7 (23 Psi) 95, >=60% Meth and >=50% Eth plus a can of NF ultra to boot. : this should be good for 600whp
Map 8 (25 psi). 95, >=60% Meth (dual nozzle setup req. min 2 x 7GHP) >=50% Eth, a lot of NF. ( you could just run 104 Ron with Meth) : I have seen a few guys hitting anywhere from 620 to +700whp
This is what I have learnt with over 70 dyno runs on the kit. (Map 1, 2 & 5)
Girevik77 said:Chucky said:Great build, looks super fun and scary at the same time.:coolShake:
Thanks bro!! :ty: It can be scary at times :fencelook: but mostly fun.
Knocking you can google to get a good explanation. In short it's when fuel air mix in the cylinder pre-detonates ie. before the spark plug ignites the mix. And you get incredibly high pressures in your cylinder because of the shock wave. And if that carries on you'll probably send a big end through your block.
Spec is a clutch manufacturer and 2+, 3 and 3+ just refers to some of the options they have. Higher number generally being for higher power and torque applications.
Map 1-7 refers to the JB4 piggback tune maps. It's a piggy back system that allow you to switch between low and high boost maps on the fly. It has loads of other nifty functions, but essentially it is just a fancy boost controller :biglol:
My buddy KrS24 explained the different maps and expectations for each map in this earlier post.
I hope this helps, feel free to ask if anything else is unclear and thanks for the interest.
