Updated parts list for the car:
ITEM	PART NUMBER	DESCRIPTION	QTY
1	11427833769	OIL FILTER	1
2	82152912152	ANTIFREEZE	5
3	11531317394	TOP RADIATOR HOSE	1
4	11531401726	BOTTOM RADIATOR HOSE	1
5	11531318274	THERMOSTAT	1
6		O RING	1
7	11521712058	FAN BLADE	1
8	11281748130	DEFLECTION ROLLER	1
9	07119904517	HEX BOLTS 6x12mm 	4
10	13531717650	BRACKET FUEL LINE	1
11	16121107928	BRACKET FUEL LINE	1
12	07119906222	FILLISTER HEAD WITH WASHER	3
13	11121317364	WATER MANIFOLD GASKET	1
14	13541401297	HEAD INLET O RING	6
15	07129952104	CLAMP	8
16	07119913662	HEX BOLT 8X30	2
17	13541307380	O RING	12
18	13541401297	ORING	6
19	11282245087	ADJ PULLEY	1
20	11281748131	ADJ PULLEY	1
21	17111719190	HALT F BRACKET	1
22	17112228090	AIR DUCT 	1
23	1711227289	AIR DUCT 	1
24	11121721879	RUBBER SEAL	22
25	23001222888	TORX BOLT	1
26	23001222894	TORX BOLT	2
27	17111712963	EXPANDING RIVET	4
28	51481915964	EXPANDING RIVET	2
29	07119903994	BOLT	1
30	7119913676	HEX BOLT AIRCON PULLEY 8X35	1
31	11511318287	WATER PUMP GASKET	1
32	7119915093	POWER S BRACKET BOLT 8X20	1
33	17201712209	OIL LINE BRACKET	2
34	17227798686	SPACER SLEEVE	1
35	11311318122	ADJUSTMENT U	1
36	13411736144	RUBBER MTNG	1
37	12141318735	BRACKET M3	1
38	13531717650	BRACKEY FUEL	1
39	16121107928	CLAMPING M3	1
40	51711977678	COVERING325	1
41	17119901299	BREATHER PIPE	1
42	23001222891	TORX BOLT	1
