ty1204 said:
Hi Guys, have a few questions regarding the JB4, hoping one of you guys can help me out...
I have an N54 335i DCT, I've already done decatted downpipes, exhaust, DCI, chargepipe with dumpvalve and software. I've recently been reading up on the JB4 and the safety features as well as the ability to switch maps on the fly are the main reasons I'm now looking at going this route, also the fact that I don't need to remap every time I add/change a new mod is a big plus. These are the questions I have....
- Can the JB be installed with the current file on the car? Is this the best way to do this or should I rather revert back to the stock map?
- I read somewhere that map6 is customisable, If I revert back to the stock map would I then be able to load my current file as map6?
- Can the back-end flash only be done with the BMS maps?
Thanks in advance for the assistance....:ty:
Howzit bud
The JB4 is a piggy back system - this functions as a means to alter expected values communicated to the car's ECU to boost performance. Maps on the JB4 are predefined altered maps (with the exception of map5 - which is auto learn and map6 - user defined tune)
JB is dynamic in the sense that altering a boost value has implications on fueling and timing (as an example) and for that reason most guys ask a tuner for help dialling in settings.
It can be used with the file already on the car - and will seek to alter the imputs as requested by the existing file on the car. You will not be able to load your current map as map6 unless the parameters set are very similarly defined and linked to the JB4 interface.
I think that any map (e.g. your existing tune) may function as a back end flash - plenty guys running VWs and BMWs alike are running JBs as a stacked option over existing flash tunes.
Hope this helps - I'm a novice here, more experienced guys will hopefully chime in.
