JB4 (N54/N55) Support Thread, South Africa
SwickedV
So finally got to experience this...
Cracked stock BMW charge pipe. Fortunately i have a CP-e one which i hadn't had time to install
Twinz
Forum - Support
Thats very common. Happens on stock cars too.
The CPe is aso known for blowing off because it does not mount to the engine bay.
But try it & keep us updated.
SwickedV
Hey Twinz
Yeah i personally havent had any issues with the CP-e pipe but I am also not running very high boost...
Will post though if I encounter any issues
FiRi@Rennzport
SwickedV said:
Hey Twinz
Try and use t clamps if you up ing the boost whilst using the CPE. The stocks clamps it comes with always give way. Trust me I've been through the hassle.
boost3d
Firoze_D said:
SwickedV said:
Hey Twinz
:roflol:
SwickedV
I have had it for a while and had no issues but not high boost
I am a little confused as to how you would use a t clamp on a metal pipe ? Do you put it over the c clamp so it doesn't pop off ?
FiRi@Rennzport
Boosted@TheFanatics said:
Firoze_D said:
SwickedV said:
Hey Twinz
:roflol:
It's doesn't pop where it connects to intake manifold. It's pops on the silicone hose that's connected to up pipe from the cooler. If you secure it there properly, then you good to go.
Ps...don't forget to transfer the O ring from oem charge pipe to the cpe
SwickedV
Yeah the first time i installed it i forgot the o ring. Felt like such an idiot. And yeah i have t clamps on the silicon house between intercooler pipe and charge pipe :)
Drama
Hi!
What is the benchmark figures for a N55 135i with JB4? I dyno'd my stock 135i at KAR and made 200.2wkw and 4xxnm which the guys said seemed healthy. Haven't dyno'd since the JB4 but am curious to know what I should be aiming for.
E63AMG
Inactive
Hey, I am looking for some help with install on my 2010 N55 135i.
I bought a second hand JB4 off the forum and have installed twice now which resulted in me uninstalling twice... It does include a flex fuel adapter so not sure if that is contributing to the issue.
Essentially I connect everything, and then try to start the car. It starts but comes up with an engine light right away. I have what sounds like a misfire but not quite a miss... Hard to explain.
Reading the logs, two get registered:
29e2 and 2c58.
Turn off and revert the install and all is hunky dory again. No issues at all.
I am suspecting something is not 100% kosher with the harness I got or the connections that are made but would like to find out if anyone has had these issues? Perhaps point me in a general direction to troubleshoot would be great!
PAGANGP
Hello, are you based in Jozi? There is an installer, Dewald Hurn, very good and also very reasonable. Google him. He did mine on the same spec and year as yours.
E63AMG
Inactive
Thanks, will do.
I've got it installed for the 3rd time now :p
Worked. Closed the DME box, works. Cable tie the harness, works. Put back the drip tray, works. Add back the AFE airbox, click click, engine light...
Definitely a connection on one of the sensors that's not perfect methinks...
Mike-R
Hey bud.
Do the following. If it's iso. Update the unit to the latest iso.
Install again. But don't install the flex fuel wires and also don't Install the maf sensor. But do the rest. Just tape it up and and test.
Sent from my SM-N910F using Tapatalk
You More than welcome to call me should you need more information.
PM me and I'll send you my number.
E63AMG
Inactive
Thanks for the advice guys! Sorted ;)
I did a latest ISO update and then realized there was two hairline cracks on the insulation of the TMAP sensor for the JB loom. Taped those up and I'm boosting away on Map 5 :)
