nawti1 said:have a question around the ISO for JB4
1- what is it?
2-How do i know if my JB4 has it? (bought the unit second hand)
3- will it make a difference to my car?
Had a few runs last night with a stage 2 + scrirroco R and wasn't impressed he managed to catch and pass in 5th,
nawti1 said:shot for the quick reply much appreciated,had the dp and jb4 installed,not happy with results so trying to investigate all possible issueraise:
BrandonF1 said:Hey guys
A question on the car adapting and changing maps:
no hardware mods. N55 Jb5 stage 2 with ISO.
How long does it take for the car to adapt once selecting map 1 or 5. I find Map 5 pulls much better, but map one is also good.
Does the vehicle have to adapt each time the difference maps are selected or is the previous info "saved in history" and continued on once the map is selected again?
Another question:
When on map 5 and occasionally on map 1 it sounds as though the car is bleeding boost through the actuator, I can hear the turbo spool but sounds as though the boost is being regulated by releasing it slightly when I am not fully on the pedal. Is this normal, thanks.
Will look to run logs this weekend.
Thanks, you have answered my question perfectly!:thumbs:Acheron said:BrandonF1 said:Hey guys
Another question:
Map 5 adaption should be complete over the course of about 3 or 4 2000 rpm to redline pulls in 3rd/4th gear. If you change maps you lose this adaption and will need to repeat the above process.
Map 1 is the "safe map" for no hardware mods and Map 5 will tune according to fuel quality, potentially giving you a whack more boost based on measure timing/knock.
As for your other question you may just be hearing the increased induction noise as a result of running higher boost. Best thing would be to read codes/run a log to determine wastegate duty cycle and requested v.s. actual boost to make sure all is well.
