gavsadler
Oh yes, something else I forgot to update with.
Rear brake pads were nearing end of life, so ended up buying oem. Fitted these together with a new sensor.
Also, whilst doing that, we did a repair on the rear outer cv boot which was torn. As with many jobs on this car, a bit of a PITA. The cv joint wouldn’t come off the shaft, and bar pulling the whole driveshaft out of the diff, we decided on another fix.
A bit agricultural, but ended up cutting the cv boot, slipping it over the CV and then superglueing the boot together again. I’m pleased to report that it is holding up well.
Also, while doing this, we noticed that the link for the stabilizer bar was completely broken off. What’s even more worrying is that it was tucked up nicely out of the way behind the dust cover for the disc.
Now I would expect that because this link hangs vertically, if it broke, it would still hang in a more or less vertical position?
I can’t prove it, but I suspect the last time someone worked on the back of this car was BMW just after we bought it 2 years ago. Maybe it was broken then and they chose to ignore fixing it? So it was tucked away.
Anyway, I managed to source one from an X3 at a local scrappy and fitted that.
Sadly for all of this, I had lots of pics, but a phone malfunction / user error means I lost everything.
