Silverbird_96kw
Hi guys,
How many of you guys use the paddle shifting when in M/S ?
Have you noticed the "harsh" shifts from 1st to 2nd, 2nd to 3rd - I don't use it often, when i did the car was still in Comfort mode and didnt give it beans just about to 3000/3500rpm just wanted to use the paddles a bit, but came on another site and seems as its normal...
Guessing I'm not use to the BMW box though - in normal Auto its smooth - can feel a change here and there but not "harsh" at all.
http://www.2addicts.com/forums/showthread.php?t=1227065
Then onto the 2nd thing, I've noticed a small amount of oil between the Gearbox and Oil Pan from date of delivery and dealership says all is normal (They have changed the tappet cover gasket as there was a a small amount of oil at the back, as well as the oil filter housing gasket as a precaution they changed)
So not sure where this small amount will come from then - as the dealership still says they cant see where its coming from, also have a letter from BMW SA where they state that all is in spec - I know not everyone will lie down and check under the car if anything is funny or not, I'm just that kind of guy :sorry:
Ive cleaned it to look like this (22 July)
And Yesterday (14 Aug) Before i cleaned it in July it did look like below aswell - not as much as on the screw...
So not sure where to say its coming from or how big of a problem it is...
