Fordkoppie said:a1exander said:the M88 is a better platform for high revs.
I dont agree completely, because see below
skank said:After doing some piston speed math the other day I worked out that an M88 with an 84mm crank will have the same piston speed (and therefore reliability) as an S38B36 at a red line of 7400. This compared to the factory 7200 redline for the S38.
It doesn't sound like much but it makes a big difference considering the shorter stroked M88 will get there faster.
The only thing counting in the M88's favour is the stroke, the rest of it is actually worse for high rpm applications compared to the s38.
While piston speed is definitely higher on the longer stroke, the rest of the s38 is way superior metallurgical and structural to handle high revs.
To name a few:
Forged S38 crank VS cast M88 crank
Mahle forged pistons on S38 VS who knows what on M88
Duplex S38 chain VS single M88 chain.
Bigger S38 valves and ports VS m88
S38 has higher valve spring rates
S38 = more duration + lift than M88
Superior crank to harmonic balancer interface on s38.
And in the real world, M88s are known to break cranks. S38s dont.
skank said:Fordkoppie said:a1exander said:the M88 is a better platform for high revs.
To name a few:
Aaagh. I can't resist anymore. This comparison has been bothering me for ages because it's bollocks. While I agree the S38 is great the M88 is right up there. BMW went bigger on the bore and stroke because the great big fat E34 wouldn't work with a high revving M88. 1750kg E34 M5 vs. 1450kg M635CSi. The timing chain went to double for reliability as customer were not following maintenance intervals, it puts more strain on the valve train and causes inertia issues.
The correct comparison is:
Forged S38 crank VS Wrong M88 crank is forged
Mahle forged pistons on S38 VS Wrong Mahle forged pistons on M88
Duplex S38 chain VS single M88 chain. Correct debatable improvement.
Bigger S38 valves and ports VS m88 Wrong they are both 37/32mm
S38 has higher valve spring rates Wrong BMW did a recall on all M88 to fit dual springs
S38 = more duration + lift than M88 Wrong Both are 264 duration and 10mm lift
Superior crank to harmonic balancer interface on s38. Maybe
We are agreed on the rest.skank said:In all honesty, I was not sure on the valves. I have obviously had M88 and M1 valves in my hand, but not B36 valves.
I can only shrug as REALOEM and BMWFANS both declare B36 valves as 37/32.
http://bmwfans.info/parts-catalog/E...engine/valve_timing_gear_cam_shaft/#1309343_3
http://www.realoem.com/bmw/enUS/showparts?id=HD93-USA-07-1990-E34-BMW-M5_36&diagId=11_1266
Even VAC lists the same for the B36. I had however had 38mm inlet in the back of my head so will acquiesce on the valves.
The rest however is correct.
To name a few:
PJ... soon.Peejay said:More pics of the entire car please Peter
Ratslaaf@OBDWorx said:It's only a pleasure Oom PietI was going to take a match to the car but, as we later found out, that wouldn't have worked anyway
