Gtech believed heavily upon the dutchman tight method.
gavsadler said:
Compliments to all who played a role in this build. Job well done it seems. (Not that you had any other option, with the amount of people watching this thread, it's important not to make your name toffee :rollsmile
And the pics and vids made it that much more pleasurable to read. Also learnt quite a bit here.
And congrats to Crash for finally getting your car back. Time to enjoy it again, and reap the rewards of all the madness.
Perhaps a suggestion (and apologies if I've missed it), but perhaps a summary of what all has been done to Jezebel overall? As well as what is new to this particular build which will differentiate it from other Ms?
Keep up the good work!
I only saw this message now. Apologies Gav.
Ok, what has been done to Jezebel overall.
She was leaking oil badly from the Sump gasket and had a horrible vibration when driving her. Obviously once pulling the engine we discovered the source of the massive vibrations. The gearbox was only held onto the engine by two bolts. The rest had either fallen out (because they were the wrong spec bolt) or where never installed. Most likely the former.
Upon opening the sump, we discovered the source of the massive leak. There simply was no metal sump gasket. Only silicon sealant which does not seal correctly.
That being said, the following was done to this engine.
BLOCK
1. The block was previously bored out to 87.5mm. Stock bore is 87mm. This makes the car roughly a 3.3litre engine as opposed to 3.2l. More low down torque.
2. The block was re-sleeved and honed using a specified pattern by CP pistons for good oil spread and less friction on the pistons during operation. This gives a more responsive engine. You can see the cross hatched lines in the cylinder walls in the photos and videos.
3. The engine currently runs CP forged pistons with stock 11:5.1 compression. The pistons weigh twice as light as OEM stock pistons. CP is a company owned by Carillo. They create Pistons for Nascar racing.
4. The engine currently runs Horsepower Freaks Crower Rods with Crower bolts. Just to give you an idea who crower are, they make rods for top fuel dragsters and they created the rods for the HPF turbo charged M3's which run well over 1400hp.
5. The engine was blueprinted and crank balanced. The engineers that Peter uses measured each piston size and bored each cylinder according to their respective piston to create the tightest seal possible for best compression. If cylinder 2 piston was 87.51mm, the bore was 87.51mm, if cylinder 3 piston was 87.48mm, the cylinder was 87.48mm.
6. New CP piston rings were brought in and correctly gaped to create the tightest oil seal so very little blow by occurs.
7. ARP L19 bolts used througout the build. Can hold over 1200hp.
8. The car has Vac Motorsports uprated oil pump gears to help move oil quicker through the engine and eliminate the chance of the oil pump gear breaking via a factory defect that occurs in some e46 M3s.
CYLINDER HEAD
1. The old stock Valves were removed and replaced with Vac motorsports High Performance race valves. These use single Large groove cotters as opposed to three small grooves. Better grip on the valve. The valves also weigh considerably less than stock, eliminating valve float on higher rpm. These race valves are also made of inconel. A very heat resistant metal that can take massive abuse on long endurance races.
2. The cylinder head was given a 3 valve cut job, thus creating a better acceleration of the air going into the engine. More air means more power.
3. Vanos seals and anti rattle kit installed.
The rest of the engine was returned to OEM standard. This was done by replacing any missing bolts or toyota bolts that where used on the engine by the previous idiots who worked on the car.
In the end, whether any of these engine upgrades truly give the car more power are to be seen. I know for a fact that the car does have more torque than stock, but HP should remain the same. The difference is, this engine revs up so fast, so smoothly, that it acquires said HP must faster and smoother, thus allowing the car to get on the power earlier.
She was built to withstand the high stresses of boost.
