I have followed the thread over the past few days but have not had the time to respond and I equally wanted the emotions to subside .
At the outset I wish to make clear that the following post is made with a heavy heart for I am seeing the demise of what I considered was a budding friendship with a very talented man and valued member of this community.
In reading Christopher’s posts one may be excused in thinking that I have been dismissive and inattentive to Christopher and his concerns however in reality I have been communicative to the extent of spending many hours in deep telephonic discussions in response to his whatsap messages. Being of the old school I tend to prefer calling a person as opposed to typing on a minute keyboard and having to look for my glasses.
Should any of you doubt my word I am sure that Christopher will confirm it once he looks at it objectively, failing which I am more than willing to send you a record of calls made to Christopher’s cell number some of which lasted for as long as an hour.
The issue at hand is that the engine has lost compression and the reason for that as promoted by Christopher is that the tune file could not be completed due to the cams being misaligned.
Before I cover the above I would like to cover a number of other issues raised by Christopher namely the misalignment of the power steering pump, the missing tensioner rail, the vanos oil pump as it will be relatively quick.
In the case of the tensioner rail, which is in fact a guide rail, it is absolutely my cock up as I overlooked that it was missing when I stripped the engine as well as when I assembled it. In mitigation of my oversight I refer you to my previous post and I quote “This is the first time we have built an s54”. The omission of the guide rail did not have any adverse effect on the running of the engine as the main tensioner carries the operation of the chain and brings the chain under tension. In other words, only under extreme circumstances would the lack of the guide rail be felt. In closing me not seeing the wood for the tress which I disclosed to Christopher when he notified me.
In the case of the misaligned power steering pump and the loose bolt I again need to accept that I should have applied myself and thought it a bit more thoroughly. However my lack of hands on experience with superchargers and not tardiness was the underlying reason for the bolt vibrating loose.
The power steering pump is secured by 2 long bolts on its face against the oil filter housing. Both the pump bracket and oil filter bracket are very wide at the mounting point.
The 2 bolts are 80mm long and serve as the primary fastening bolts.
At the back of the pump there is a bracket which locates against the engine sump which takes a far shorter bolt and it is used as a stabilising point so that the pump does not deflect upwards or downwards when under load from the serpentine belt.
Under normal operating circumstances the small bolt set at 15Nm of torque is sufficient in design to withstand the loading forces and stay in place.
Given that the supercharger was fitted and a number of belt lengths were tried to get the correct set it would have been prudent to secure the bolt with some semi permanent Loctite so as to insure that the vibration induced by the belt would not back the bolt out.
For those that might be wondering as to why the supercharger would or could have an effect on that bolt consider that the supercharger is fitted with a serpentine belt that is considerably longer and it creates a lot more oscillation of the belt when it loads and unloads under boost. In other words when you accelerate and decelerate.
The movement of the belt was overcome by Christopher’s initiative in replacing the stock hydraulic tensioner idler with a mechanically sprung unit and tightening the bolt beyond factory spec .
With regard to the vanos oil pump it is worth noting the fact that I changed the complete vanos body pistons pump covers bolts and solenoid on the engine after the first set of errors we experienced with the vanos That was done and Christopher was informed of the change. The change was done at no charge for the new body .I wanted to eliminate any potential errors. Should you wish your old unit back I have it here available for you and will refit it free of charge as I cannot use it on another car as I am suspect of it.
Vanos units have an A and B oil pump disc and one cannot mix the discs with the shafts.
After that change you may recall that adaptations that were checked with you and Alex were in the -0.2 range and the firing smoothness across all cylinders was even.
That was the period prior to the fitting of the supercharger whilst the car was being run in.
With specific regard to the fitment costs associated with the supercharger it is wrong of one to propose that I undertook the task under false pretenses as when I met with Christopher I made it abundantly clear that there would be a charge for me to sort out the installation as it required stripping and correctly re installing the system.
There is a post on the forum with pics of what was accomplished in having the system fitted initially and also pics of what I accomplished.
I do not believe that I need to develop this any further as it would be entering to disclosure of parties who may have or may not have agreed to terms with you.
One is able to quickly establish that the installation in terms of completeness and neatness was of a very high level.
Equally my morning spent trying to resolve the injector issue and travelling around was time afforded on the basis of wanting the installation to be as complete and precise as possible and was not charged for.
I would now like to move to the setting of the camshafts and the allegations/hypothesis that the engine failed due to the cams being so out of alignment as to preclude the ability to perform a comprehensive AFR test under real life conditions.
At the outset I would wish to dispute the assertion that “Alain’s” car runs the exact tune file as is presently on Christopher's car.
No two supercharged cars can run an identical ALPHA N tune file if the plenums are different if the pistons are different if the head flow is different etc etc.
To propose that Alain’s car runs an identical file to Christopher’s car with such vast differences in engine and head work as well as plenum design would immediately raise alarm bells and caution.
I would almost be inclined to say that having an identical tune file on Christopher’s car and Alain’s car may well border on the irresponsible.
I shall specifically cover the cam setting a little later however for now I should like to make the following observations.
It has been stated that the cams being out of alignment did not afford the opportunity to get the base file (the start up ecu fuel commands/engine management software) developed into a proper tune file as the proper AFRs (Air to Fuel Ratio) could not be recorded .
For those in the know the car is run on an ALPHA N tune.
It is equally claimed that in early December the cams were set by someone else correctly.
I can confirm that the cams were set correctly as Christopher called on me and I checked the alignment of the cams with the factory tool and equally completed a compression test on the engine during which time it recorded 145 across all cylinders.
During our time together I stressed in no uncertain terms the need to get the correct tune on the car as running the base tune would lead to disaster as the car was under extreme over-under fueling conditions.
(My understanding is that a base file is used for the purpose of starting the car and then proceeding to “log” the car so that the tuner has sufficient information to complete the correct tune file for the specific engine.)
The question that comes to mind is as follows, if it is true that the “erroneous” cam setting was a hindrance in getting an accurate record of AFRs prior to the cams being factory set in early December what exactly was the obstacle in having the car logged and correctly tuned post the correction of the cams? Remember at the time of the timing issue being corrected compression was an even 145psi across all cylinders.
As at 26th March 2015 the correct tune file was still not on the car and I quote(08;25) “Crash I take it that the tune file is on.” And his response (12:04) “No not yet but has been logged and sent to ----- guy”
As recently as some 10 days ago Christopher confirmed to me during one of our frequent meetings that the tune file still had not been installed on the car.
For those of you who may wish to know the reason/s Christopher did not get the opportunity to ever load the correct tune file on his car please feel free to p.m. him as I am not at liberty to disclose them.
So to recap from early December when the car could have been logged, it was not.
My warning that the engine was in imminent danger of self-destruction was not heeded and that came to pass sometime in February where I did a second compression test and the engine recorded the 105 on cylinder 4 and 5.
(Christopher I wish to make it abundantly clear that I take no pleasure whatsoever in making the above assertions as the bottom line is that an engine that was put together with a fair amount of passion and dedication (your editing skills aside) was rendered into a lump of metal. Christopher I was, and still am, as disappointed and upset as you are and that was the primary reason that I committed to rebuilding the engine when we discovered in February that we had lost compression. At the time, if you recall, I said to you that who was to blame and what was to blame was secondary to us getting the engine healthy.) The offer to assist in the rebuild was motivated by a sense of kinship rather than an acceptance or admission of guilt. ( I refer you to my opening paragraph)
To the best of my knowledge and as confirmed by Christopher herewith is a copy of the AFRs as recorded with the base file tune on the car.
For those of you who may not fully understand the numbers common practice would be to have a range of 13 parts of air to 1 part of fuel on the “rich scale” and 14 parts of air to 1 part of fuel on the “lean state” The above is an oversimplification and only used for the purposes of establishing an average.
Therefore an AFR of 9:1 would mean that the engine would be fed with an excessive amount of fuel which would lead to a dilution of the oil in the sump as not all the fuel will be burned. The unburned fuel will wash the cylinders of the protective film of oil thus allowing contact between the piston and the bore thereby inducing a higher amount of friction between the rings and the bore.
A ratio of 15:1 would mean an inadequate amount of fuel leading to excessive heat on the crown of the piston as well as the top compression ring and could lead to broken rings and ring lands.
So in summary, a state of over/under fueling will lead to bore glaze broken rings broken ring lands damaged bearing surfaces etc etc etc. I expect some of these symptoms are likely to surface during the engine tear down.
This is the Full throttle AFR record
Session: Session 15
time PSR_AFR_O2 PSR_AFR_RPM PSR_AFR_RPM
(sec) (AFR) (RPM) (RPM)
0 11.58 0 870
0.08192 11.57 0 880
0.16384 11.58 0 880
0.24576 11.55 0 880
0.32768 11.57 0 880
0.4096 11.55 0 880
0.49152 11.57 0 880
0.57344 11.54 0 880
0.65536 11.57 0 880
0.73728 11.55 0 880
0.8192 11.55 0 880
0.90112 11.54 0 880
0.98304 11.55 0 880
1.06496 11.55 0 890
1.14688 11.55 0 890
1.2288 11.54 0 900
1.31072 11.55 0 900
1.39264 11.57 0 900
1.47456 11.55 0 900
1.55648 11.55 0 920
1.6384 11.57 0 940
1.72032 11.57 0 980
1.80224 11.55 0 1010
1.88416 11.57 0 1040
1.96608 11.57 0 1070
2.048 11.58 0 1060
2.12992 11.57 0 1040
2.21184 11.55 0 990
2.29376 11.54 0 940
2.37568 11.55 0 910
2.4576 11.54 0 870
2.53952 11.52 0 880
2.62144 11.52 0 890
2.70336 11.5 0 1000
2.78528 11.48 0 1110
2.8672 11.48 0 1170
2.94912 11.48 0 1230
3.03104 11.45 0 1230
3.11296 11.47 0 1220
3.19488 11.47 0 1200
3.2768 11.47 0 1170
3.35872 11.48 0 1150
3.44064 11.48 0 1120
3.52256 11.51 0 1090
3.60448 11.55 0 1060
3.6864 11.6 0 1100
3.76832 11.64 0 1140
3.85024 11.66 0 1230
3.93216 11.7 0 1320
4.01408 11.76 0 1360
4.096 11.83 0 1390
4.17792 11.92 0 1470
4.25984 12.01 0 1540
4.34176 12.17 0 1580
4.42368 12.38 0 1620
4.5056 12.36 0 1680
4.58752 12.41 0 1740
4.66944 12.47 0 1790
4.75136 12.49 0 1840
4.83328 12.48 0 1880
4.9152 12.58 0 1920
4.99712 12.69 0 1970
5.07904 12.83 0 2010
5.16096 12.91 0 2110
5.24288 13.04 0 2200
5.3248 13.26 0 2250
5.40672 13.41 0 2300
5.48864 13.66 0 2360
5.57056 13.73 0 2410
5.65248 13.89 0 2410
5.7344 13.92 0 2410
5.81632 13.97 0 2440
5.89824 13.98 0 2470
5.98016 14.02 0 2440
6.06208 14.01 0 2400
6.144 14.04 0 2330
6.22592 14.08 0 2260
6.30784 14.11 0 2150
6.38976 14.63 0 2030
6.47168 14.49 0 1900
6.5536 14.86 0 1760
6.63552 14.8 0 1700
6.71744 15.39 0 1630
6.79936 15.23 0 1590
6.88128 15.29 0 1540
6.9632 15.3 0 1500
7.04512 15.33 0 1450
7.12704 15.3 0 1330
7.20896 15.26 0 1210
7.29088 15.27 0 1050
7.3728 15.17 0 880
7.45472 14.94 0 910
7.53664 14.73 0 940
7.61856 14.79 0 980
7.70048 14.71 0 1010
7.7824 14.52 0 1040
7.86432 14.33 0 1060
7.94624 13.91 0 1080
8.02816 13.6 0 1090
8.11008 13.2 0 1100
8.192 13.01 0 1110
8.27392 12.79 0 1130
8.35584 12.67 0 1140
8.43776 12.54 0 1160
8.51968 12.45 0 1170
8.6016 12.36 0 1190
8.68352 12.27 0 1210
8.76544 12.19 0 1250
8.84736 12.02 0 1290
8.92928 12.01 0 1320
9.0112 11.91 0 1340
9.09312 11.72 0 1380
9.17504 11.48 0 1410
9.25696 11.23 0 1430
9.33888 11.05 0 1450
9.4208 10.83 0 1470
9.50272 10.69 0 1480
9.58464 10.57 0 1470
9.66656 10.42 0 1450
9.74848 10.32 0 1470
9.8304 10.22 0 1480
9.91232 10.11 0 1500
9.99424 10.05 0 1520
10.07616 10 0 1540
10.15808 9.94 0 1560
10.24 9.91 0 1560
10.32192 9.86 0 1560
10.40384 9.85 0 1570
10.48576 9.82 0 1580
10.56768 9.8 0 1610
10.6496 9.79 0 1630
10.73152 9.76 0 1640
10.81344 9.75 0 1650
10.89536 9.7 0 1670
10.97728 9.67 0 1680
11.0592 9.64 0 1700
11.14112 9.61 0 1720
11.22304 9.6 0 1750
11.30496 9.6 0 1770
11.38688 9.64 0 1790
11.4688 9.73 0 1800
11.55072 9.79 0 1810
11.63264 9.88 0 1820
11.71456 9.95 0 1860
11.79648 9.92 0 1890
11.8784 9.91 0 1880
11.96032 9.95 0 1870
12.04224 9.88 0 1820
12.12416 10.22 0 1770
12.20608 9.91 0 1830
12.288 9.79 0 1880
12.36992 10.05 0 2090
12.45184 9.92 0 2290
12.53376 9.8 0 2040
12.61568 10.07 0 1790
12.6976 9.98 0 1990
12.77952 9.97 0 2180
12.86144 9.97 0 2160
12.94336 10 0 2130
13.02528 10 0 2110
13.1072 9.97 0 2080
13.18912 9.85 0 2140
13.27104 9.75 0 2190
13.35296 9.57 0 2220
13.43488 9.47 0 2250
13.5168 9.54 0 2280
13.59872 10.11 0 2310
13.68064 10.64 0 2350
13.76256 11.3 0 2380
13.84448 11.47 0 2410
13.9264 11.69 0 2440
14.00832 11.82 0 2470
14.09024 11.98 0 2500
14.17216 12.08 0 2530
14.25408 12.29 0 2560
14.336 12.32 0 2620
14.41792 12.41 0 2680
14.49984 12.42 0 2720
14.58176 12.38 0 2750
14.66368 12.3 0 2780
14.7456 12.14 0 2810
14.82752 12 0 2850
14.90944 11.8 0 2880
14.99136 11.7 0 2920
15.07328 11.66 0 2950
15.1552 11.66 0 2980
15.23712 11.69 0 3000
15.31904 11.67 0 3040
15.40096 11.6 0 3080
15.48288 11.55 0 3110
15.5648 11.6 0 3140
15.64672 11.73 0 3170
15.72864 11.83 0 3200
15.81056 11.85 0 3230
15.89248 11.85 0 3260
15.9744 11.76 0 3300
16.05632 11.7 0 3340
16.13824 11.6 0 3370
16.22016 11.51 0 3400
16.30208 11.48 0 3440
16.384 11.36 0 3470
16.46592 11.29 0 3510
16.54784 11.22 0 3540
16.62976 11.17 0 3580
16.71168 11.17 0 3610
16.7936 11.11 0 3640
16.87552 11.13 0 3670
16.95744 11.13 0 3710
17.03936 11.16 0 3750
17.12128 11.16 0 3780
17.2032 11.16 0 3800
17.28512 11.14 0 3850
17.36704 11.14 0 3900
17.44896 11.13 0 3930
17.53088 11.17 0 3950
17.6128 11.17 0 3970
17.69472 11.29 0 3990
17.77664 11.19 0 4040
17.85856 11.13 0 4080
17.94048 11.11 0 4130
18.0224 11.08 0 4180
18.10432 11.07 0 4210
18.18624 11.04 0 4240
18.26816 10.95 0 4280
18.35008 10.92 0 4320
18.432 10.76 0 4350
18.51392 10.79 0 4380
18.59584 10.75 0 4420
18.67776 10.67 0 4450
18.75968 10.55 0 4490
18.8416 10.54 0 4530
18.92352 10.5 0 4570
19.00544 10.42 0 4600
19.08736 10.35 0 4640
19.16928 10.3 0 4670
19.2512 10.26 0 4710
19.33312 10.25 0 4740
19.41504 10.2 0 4790
19.49696 10.17 0 4830
19.57888 10.16 0 4870
19.6608 10.13 0 4900
19.74272 10.1 0 4940
19.82464 10.08 0 4970
19.90656 10.08 0 5000
19.98848 10.07 0 5030
20.0704 10.05 0 5080
20.15232 10.04 0 5120
20.23424 10.04 0 5150
20.31616 10.03 0 5180
20.39808 10.03 0 5230
20.48 10.01 0 5280
20.56192 10.01 0 5330
20.64384 10.01 0 5380
20.72576 10.01 0 5410
20.80768 10.01 0 5430
20.8896 10.03 0 5490
20.97152 10.01 0 5540
21.05344 10.01 0 5560
21.13536 10.01 0 5580
21.21728 10.01 0 5610
21.2992 10.01 0 5630
21.38112 10.01 0 5680
21.46304 10.07 0 5720
21.54496 10 0 5760
21.62688 10 0 5790
21.7088 10.01 0 5830
21.79072 10.01 0 5860
21.87264 10.04 0 5900
21.95456 10.04 0 5940
22.03648 9.98 0 5990
22.1184 10.07 0 6030
22.20032 10.08 0 6070
22.28224 10.13 0 6100
22.36416 10.16 0 6140
22.44608 10.2 0 6170
22.528 10.25 0 6210
22.60992 10.29 0 6240
22.69184 10.3 0 6280
22.77376 10.36 0 6310
22.85568 10.36 0 6360
22.9376 10.41 0 6400
23.01952 10.42 0 6450
23.10144 10.47 0 6490
23.18336 10.54 0 6510
23.26528 10.51 0 6530
23.3472 10.54 0 6570
23.42912 10.54 0 6610
23.51104 10.47 0 6650
23.59296 10.6 0 6690
23.67488 10.58 0 6750
23.7568 10.6 0 6800
23.83872 10.58 0 6840
23.92064 10.57 0 6870
24.00256 10.54 0 6900
24.08448 10.53 0 6920
24.1664 10.5 0 6980
24.24832 10.47 0 7040
24.33024 10.45 0 7060
24.41216 10.45 0 7070
24.49408 10.41 0 7130
24.576 10.39 0 7180
24.65792 10.48 0 7210
24.73984 10.42 0 7230
24.82176 10.39 0 7260
24.90368 10.41 0 7290
24.9856 10.35 0 7110
25.06752 10.29 0 6920
25.14944 10.19 0 7020
25.23136 10.14 0 7120
25.31328 10.16 0 7130
25.3952 10.23 0 7130
25.47712 10.38 0 7080
25.55904 10.51 0 7030
25.64096 10.63 0 6980
25.72288 10.73 0 6920
25.8048 10.89 0 6920
This is the Part Throttle AFR record
Session: Session 14
0 19.37 0 660
0.08192 20.58 0 690
0.16384 22.31 0 710
0.24576 22.39 0 740
0.32768 22.39 0 760
0.4096 22.39 0 790
0.49152 22.39 0 820
0.57344 21.54 0 840
0.65536 19.79 0 860
0.73728 17.38 0 880
0.8192 17.18 0 900
0.90112 16.66 0 920
0.98304 15.86 0 930
1.06496 15.26 0 950
1.14688 14.73 0 960
1.2288 14.29 0 980
1.31072 13.94 0 1000
1.39264 13.63 0 1020
1.47456 13.35 0 1030
1.55648 13.04 0 1040
1.6384 12.89 0 1050
1.72032 12.63 0 1070
1.80224 12.66 0 1080
1.88416 12.51 0 1090
1.96608 12.42 0 1100
2.048 12.41 0 1120
2.12992 12.29 0 1130
2.21184 12.26 0 1140
2.29376 12.2 0 1140
2.37568 12.14 0 1150
2.4576 12.08 0 1160
2.53952 12.05 0 1170
2.62144 12 0 1170
2.70336 11.98 0 1190
2.78528 11.98 0 1210
2.8672 11.94 0 1220
2.94912 11.92 0 1230
3.03104 11.91 0 1240
3.11296 11.91 0 1250
3.19488 12.01 0 1260
3.2768 11.92 0 1270
3.35872 11.95 0 1280
3.44064 11.95 0 1280
3.52256 12.13 0 1290
3.60448 12.04 0 1300
3.6864 12.08 0 1310
3.76832 12.14 0 1320
3.85024 12.19 0 1330
3.93216 12.25 0 1340
4.01408 12.29 0 1350
4.096 12.36 0 1360
4.17792 12.42 0 1380
4.25984 12.51 0 1390
4.34176 12.6 0 1410
4.42368 12.73 0 1430
4.5056 12.94 0 1440
4.58752 13.1 0 1450
4.66944 13.27 0 1470
4.75136 13.38 0 1490
4.83328 13.57 0 1530
4.9152 13.63 0 1560
4.99712 13.7 0 1570
5.07904 13.64 0 1570
5.16096 13.6 0 1600
5.24288 13.41 0 1620
5.3248 13.35 0 1650
5.40672 13.02 0 1670
5.48864 12.92 0 1690
5.57056 12.86 0 1710
5.65248 12.86 0 1730
5.7344 12.88 0 1750
5.81632 12.88 0 1770
5.89824 12.89 0 1790
5.98016 12.88 0 1820
6.06208 12.86 0 1840
6.144 12.85 0 1870
6.22592 12.82 0 1900
6.30784 12.74 0 1930
6.38976 13.01 0 1950
6.47168 13.05 0 1890
6.5536 12.8 0 1820
6.63552 12.69 0 1980
6.71744 11.85 0 2130
6.79936 11.35 0 2220
6.88128 11.1 0 2310
6.9632 10.76 0 2130
7.04512 10.64 0 1950
7.12704 10.53 0 2070
7.20896 10.5 0 2180
7.29088 10.47 0 2290
7.3728 10.39 0 2400
7.45472 10.51 0 2420
7.53664 10.5 0 2430
7.61856 10.47 0 2450
7.70048 10.58 0 2470
7.7824 10.72 0 2490
7.86432 10.85 0 2510
7.94624 11.02 0 2540
8.02816 11.54 0 2570
8.11008 12.08 0 2600
8.192 12.41 0 2630
8.27392 12.67 0 2660
8.35584 12.66 0 2690
8.43776 12.57 0 2730
8.51968 12.38 0 2770
8.6016 12.36 0 2810
8.68352 12.35 0 2840
8.76544 12.41 0 2880
8.84736 12.45 0 2920
8.92928 12.51 0 2950
9.0112 12.55 0 2970
9.09312 12.57 0 3010
9.17504 12.49 0 3040
9.25696 12.44 0 3070
9.33888 12.42 0 3090
9.4208 12.39 0 3120
9.50272 12.44 0 3150
9.58464 12.42 0 3190
9.66656 12.52 0 3220
9.74848 12.51 0 3260
9.8304 12.58 0 3290
9.91232 12.61 0 3330
9.99424 12.67 0 3360
10.07616 12.7 0 3390
10.15808 12.79 0 3420
10.24 12.82 0 3460
10.32192 12.82 0 3490
10.40384 12.8 0 3530
10.48576 12.79 0 3570
10.56768 12.85 0 3600
10.6496 12.85 0 3630
10.73152 12.89 0 3670
10.81344 12.92 0 3710
10.89536 12.92 0 3740
10.97728 12.88 0 3770
11.0592 12.86 0 3810
11.14112 12.89 0 3850
11.22304 12.95 0 3890
11.30496 13.01 0 3920
11.38688 13.02 0 3950
11.4688 13.04 0 3980
11.55072 13.07 0 4020
11.63264 13.1 0 4050
11.71456 13.13 0 4090
11.79648 13.17 0 4120
11.8784 13.22 0 4160
11.96032 13.27 0 4200
12.04224 13.26 0 4240
12.12416 13.27 0 4280
12.20608 13.36 0 4310
12.288 13.41 0 4330
12.36992 13.44 0 4410
12.45184 13.49 0 4480
12.53376 13.51 0 4540
12.61568 13.55 0 4590
12.6976 13.66 0 4610
12.77952 13.73 0 4630
12.86144 13.73 0 4640
12.94336 13.79 0 4640
13.02528 13.83 0 4680
13.1072 13.82 0 4720
13.18912 13.83 0 4760
13.27104 13.86 0 4790
13.35296 13.83 0 4820
13.43488 13.91 0 4850
13.5168 13.89 0 4880
13.59872 13.92 0 4910
13.68064 13.77 0 4950
13.76256 13.94 0 4980
13.84448 13.98 0 5030
13.9264 13.92 0 5070
14.00832 13.97 0 5100
14.09024 13.98 0 5130
14.17216 13.98 0 5160
14.25408 14.17 0 5190
14.336 13.98 0 5220
14.41792 14.24 0 5250
14.49984 14.08 0 5280
14.58176 14.2 0 5310
14.66368 14.21 0 5340
14.7456 14.26 0 5370
14.82752 14.33 0 5410
14.90944 14.39 0 5440
14.99136 14.39 0 5480
15.07328 14.45 0 5510
15.1552 14.74 0 5540
15.23712 14.55 0 5560
15.31904 14.33 0 5600
15.40096 14.57 0 5640
15.48288 14.44 0 5660
15.5648 14.58 0 5680
15.64672 14.69 0 5720
15.72864 14.71 0 5750
15.81056 14.61 0 5790
15.89248 14.67 0 5820
15.9744 14.67 0 5860
16.05632 14.74 0 5890
16.13824 14.74 0 5920
16.22016 14.79 0 5950
16.30208 14.88 0 5980
16.384 14.91 0 6000
16.46592 14.91 0 6040
16.54784 14.83 0 6070
16.62976 14.82 0 6110
16.71168 14.95 0 6140
16.7936 15.02 0 6180
16.87552 14.95 0 6210
16.95744 14.79 0 6250
17.03936 14.71 0 6290
17.12128 14.94 0 6330
17.2032 14.55 0 6360
17.28512 14.74 0 6380
17.36704 14.91 0 6400
17.44896 15.1 0 6440
17.53088 15.08 0 6470
17.6128 15.1 0 6500
17.69472 14.74 0 6520
17.77664 14.99 0 6560
17.85856 14.96 0 6590
17.94048 14.91 0 6620
18.0224 15.1 0 6650
18.10432 15.08 0 6690
18.18624 15.07 0 6720
18.26816 14.95 0 6750
18.35008 14.86 0 6770
18.432 14.94 0 6810
18.51392 14.7 0 6850
18.59584 14.96 0 6880
18.67776 14.49 0 6910
18.75968 14.74 0 6910
18.8416 14.83 0 6910
18.92352 14.51 0 6950
19.00544 14.7 0 6980
19.08736 14.66 0 7020
19.16928 14.63 0 7050
19.2512 14.63 0 7090
19.33312 14.61 0 7130
19.41504 14.52 0 7160
19.49696 14.55 0 7180
19.57888 14.61 0 7220
19.6608 14.51 0 7260
19.74272 14.54 0 7260
19.82464 14.52 0 7260
19.90656 14.55 0 7100
19.98848 14.8 0 6940
20.0704 16.58 0 6690
20.15232 16.8 0 6430
20.23424 16.92 0 6190
20.31616 17.42 0 5940
20.39808 17.04 0 5570
20.48 17.21 0 5200
20.56192 17.15 0 5160
20.64384 17.21 0 5120
20.72576 17.18 0 5040
20.80768 17.17 0 4960
20.8896 17.26 0 4930
20.97152 17.3 0 4900
21.05344 17.43 0 4840
21.13536 17.63 0 4780
21.21728 17.86 0 4720
21.2992 17.83 0 4650
21.38112 18.24 0 4600
21.46304 18.39 0 4540
21.54496 18.71 0 4460
21.62688 18.79 0 4380
21.7088 19.15 0 4310
21.79072 19.39 0 4240
21.87264 19.8 0 4190
21.95456 20.29 0 4140
22.03648 20.61 0 4000
22.1184 21.08 0 3850
22.20032 21.39 0 3700
22.28224 21.74 0 3550
22.36416 22.14 0 3410
22.44608 22.39 0 3260
22.528 22.39 0 3130
22.60992 22.39 0 2990
22.69184 22.39 0 2860
22.77376 22.39 0 2720
22.85568 22.39 0 2580
22.9376 22.39 0 2430
23.01952 22.39 0 2170
23.10144 22.39 0 1900
23.18336 22.39 0 1830
23.26528 22.39 0 1750
23.3472 22.39 0 1660
23.42912 22.39 0 1560
23.51104 22.39 0 1480
23.59296 22.39 0 1390
23.67488 22.39 0 1340
23.7568 22.39 0 1290
23.83872 22.39 0 1270
23.92064 22.39 0 1240
24.00256 22.39 0 1220
24.08448 22.39 0 1200
24.1664 22.39 0 1190
24.24832 22.39 0 1170
24.33024 22.39 0 1150
24.41216 22.39 0 1130
24.49408 22.39 0 1120
24.576 22.39 0 1100
24.65792 22.39 0 1090
24.73984 22.39 0 1070
24.82176 22.39 0 1060
24.90368 22.39 0 1040
24.9856 22.39 0 1030
25.06752 22.39 0 1010
25.14944 22.39 0 1010
I would also like to make mention of the allegation that the engine was in a closed loop operating cycle and over fueling due to the cams being out of alignment.
It is important that one takes into consideration that the engine ecu upon startup will go into a pre-programed pattern where a specific amount of fuel is used to idle the engine with no particular reference to sensors.
Once the engine has warmed up it then relies on the following to determine what quantity of fuel will be required:
Crank position
Exhaust cam position
Inlet cam position
Throttle position
MAF
Air intake temperature sensor
Coolant temperature sensor
Exhaust gas temperature sensor
On the proviso that the engine has gone out of the “fast idle” cycle it settles down from its preset running to an active monitoring program where info from all the sensors is used to record the engine load and air intake and thus, the appropriate fuel.
So provided the cams and crank are within a range recognized by the ecu the ecu will supply the fuel for that specific operating range.
The assertion that the engine was in a constant closed loop state is erroneous for as soon as the engine warmed up it would naturally seek signals and reference markers from the cams crank O2 sensors as well as throttle and in the ALPHA N cars the air temp sensor
If the signal from the cams did not correlate with the crankshaft, the engine would go into fail safe mode and the EML would shine like a beacon….that would obviously preclude the car from annihilating a Porsche as well as an SRT V8 Chrysler as well as many other unfortunates including a normally aspirated car that belonged to an active member.
In closing I have oversimplified the operation for the sake of keeping it simple however the substance would be the same even if I were to go into the minutiae of the monitoring/fuel supply.
In closing this will be my last post on the matter and I invite those of you who have questions to contact me via p.m. sms whatsap e-mail telephone or a visit to my home. You shall be most welcome irrespective of who it is and I will to the best of my ability address your concerns.
On my next post I shall cover the question of the cam setting however I need to gather a number of photographs to illustrate my point. I ask for your indulgence in affording me the opportunity to do so.
