Corsa C Ute - Another Toy Story
FiRi@Rennzport
Bro these opels are so underrated.
We sold our 2001 1.8 wagon 2 months back. Car covered 430k kilos over the 20 years it stayed with us and worked like a charm. Ecu finally gave up in April and new owner just fitted dictator system. No oil leaks over 20 years, just a workhorse of note.
Sent from my SM-G998B using Tapatalk
Nicely done Gav, this van is extremely well kept, proper sleeper,
I didn't know the OOC is still alive, do they have a website, give me some info man :)
gavsadler
Update Oct-21 to Nov-21:
I've revived work on the cars the past couple of months, and the Ute has had some long overdue updates. It has worked particularly hard the past few months, loading carrying all sorts of stuff. The suspension refresh has been on the cards for months, and having got most of the parts together, I was just waiting for front shocks to arrive from Europe.
On the list of items to be replaced:
  • Front shocks (Koni)
  • Front shock mounts (Meyle)
  • Front stabiliser links (Meyle, I think)
  • Front Control Arms (Topran - all that is available close by)
  • Rear shocks (Koni)
First up, the back of the Ute went up, and the old shocks removed, and replaced with new ones. Note that the old shocks were not bad, but they've been in for 10yrs/100000kms odd, so I thought it's best to change in the bigger scheme of things.
Next was to move to the front of the Ute. All bits were removed, and the springs were transferred over from the old shocks to the new shocks. New shock mounts also fitted.
While things were off, I also arranged to have the front discs skimmed very slightly, just to make the face true and flat again, and eliminate any points of squeal from touching on the pads at the edges (there has been an annoying squeal since fitting the new pads a while back). Vari did the skim and slotted the discs again. There is still plenty of life left on these discs, I think if maybe 1mm was skimmed off, it was a lot.
All buttoned up on one side:
With the brakes done, I also did a quick seat clean using some Wynn's Brush Off, and this has revived the fabric. At some point I will look to do a deep clean with a proper machine.
gavsadler
And with the new shocks fitted, the Ute drives so much better, almost like new. Next on the agenda was 2 new front tyres. I got a bad puncture in one of them earlier in the year, necessitating me fitting a spare tyre from my brother-in-law. This was supposed to be a temporary measure, but ended up staying on for months while other things took priority.
Anyway, off to my friends at TWT Meadowdale. Tyres of choice were the same as previously fitted (and still fitted on the back): Hankook Ventus V12 Evo2. They offer great performance and I've been happy with them. They stood up to lots of abuse at the track day a few years back, and have done very well in terms of wear.
After doing this, I was even more pleased with how the Ute was driving. Peace of mind that it has finally been done is also worth a lot.
Then, just 3 days later, on the highway there was a horrible vibration through the steering wheel. I was mildly annoyed, as the balancing was done, yet it seemed worse now than with the old tyres. This required further investigation. Then a day or 2 later, the Ute sounded like a jet plane taking off as speed increased from standstill. It was not brake related, nor was it related to any particular gear.
With some more head scratching, I thought possibly that a wheel bearing was failing. We jacked up the Ute, and I guess it was no surprise that there was a lot of play on the left front wheel. So my wheel bearing fitted earlier this year, and having covered about 7000kms odd, had failed.
We jacked up the right hand side, and this also feels like it's starting to have some play. So.... back up on trestles, and the front steering knuckles and hubs had to come out. New parts have been purchased, and these are currently being pressed into the steering knuckles. I should collect this week sometime.
Also, while everything was stripped out, I thought to attend to another annoying noise which has been there for quite some time - a clicking noise each time the Ute starts to move from standstill. This is indicative of a failing CV joint, given that all other parts have been replaced now.
So, out came the RHS drive shaft, and this confirmed my suspicions, the inner CV has some play in it. I've spent a couple of hours replacing the inner and outer CV joints on this driveshaft. It's back in, and now just waiting on the steering knuckles to come back. Then the Ute should be good to go for another while. The only other issue on the radar then will be to overhaul the head at some stage...
That's all for now.
gavsadler
Benji
Quite a lot of work has gone into this car! Do you think the bigger engine & more power are the cause of the failing bearings? I seem to recall this is the 3rd time youre doing bearings?
gavsadler
Update Nov-21 to Mar-22:
Life has been happening, a lot. As such, I've not spent much time on the forum, or on the cars for that matter. Nevertheless, I'm going to bring all my threads up to date.
As mentioned in my previous posts, I was waiting on the new wheel bearings and hubs to be pressed into the steering knuckles. @Benji: I suspect the most recent cause of failure was inferior bearings which were supplied previously. The guys at Goldwagen also commented on how they are noticing an increase in failures of parts, with the cheaper stuff being brought in, as opposed to the tried and tested parts, which cost about 50% more. I sourced FAG bearings for this iteration, which is what I have used in the past and which lasted longer.
That was one of the last pieces of the puzzle to get the Ute back on the road, and since then, it has been working hard. Moving furniture, household items, garden refuse, building rubble, garage tools and equipment and more. Literally every week has seen it being loaded with something or the other, which would not be possible with a regular vehicle/van.
In Feb-22, I had some time to spend on a wash, so managed to snap some pics of the newer wheel and tyre brushes currently in my arsenal. These include the Wheel Brush Kit and Boars Hair brush from Detail Factory, and the Wheel and Tyre Brushes from The Rag Company these products are all available in the G Shift Online Store). My other tried and tested brushes are still in use, with plans to refresh these soon.
With all the use over the past few months, the steering wheel also needed to be sanitised and cleaned, so spent some time doing that as well:
The Ute is due for a service, and I've been gathering up all the tooling and parts required for the additional surgery on the valve stem seals. I'll also be fitting a new cambelt and water pump at the same time, and tending to whatever else needs to be done. Hopefully I'll get that done during the month of April.
That's all for the moment on this one...
gavsadler
Update: Apr-22 to Oct-22:
This year has been crazy, to say my day job has been demanding the past 6 months would be an understatement. This, coupled with the start of some home renovations from May-July meant that everything else has had to be on auto-pilot: friends, family, car stuff, G Shift, the works. Thankfully some normalisation has returned and I can start to balance things out again.
Around the middle of April, I decided to tackle one of the many overdue jobs on the Ute, that being to replace the coil pack plug on the wiring harness. I’ve done this previously. It seems to be a common issue on these, where the rubber insulating piece on the plug itself does not block out all moisture. Over time, the pins in the plug corrode, resulting in poor connection and then subsequent misfire which I was starting to experience. Fast forward a few hours later on a Saturday, and the plug was swapped out, yet the Ute was now idling constantly with a misfire.
I re-checked all my joins on the new plug, and traced and checked other wires in the harness, fuses and so on – no luck. Eventually, I traced the issue back to an issue on the ECU board itself. I contacted Spitronics and made arrangements to go visit their area agent to check and repair. It turns out that the transistor for ignition to Cyl4 had blown. In the pic below, you will see the suspicious contacts circled in red. And the blown transistor seen from the other side of the board.
About 10mins later the ECU was repaired, at no charge, and I headed back to refit and test. Big thanks to the Spitronics team, their customer service has always been great in my opinion. I refitted the ECU and the Ute started up 1st time and idled smoothly once again. We are not sure what could have caused the transistor to blow, I suspect maybe current jumping between the corroded terminals on the coil pack plug or something.
With the Ute back to driving duty, it was about to become a long and hard few months of work ahead. Starting off with clearing out a lot of stuff from my Parent’s house which had been sold. I moved everything from furniture, to boxes, to appliances, to bricks, and of course some shelving. Some pics below of workhorse duties taking place.
This was approx. 250 bricks on the back, and some scaffolding and other bits and pieces:
As the move from that house was winding up, we began with some renovations at our home. Once again the Ute became a runner up and down to Builder’s Warehouse countless times to get things which were overlooked / not supplied by the contractors. This included a few loads of tile adhesive:
With the Ute working hard daily, the smoking issue became more apparent as the days went by. I have suspected that the valve stem seal(s) were getting a bit tired (200000kms+ on the motor), so one week when things were a bit quiet, I decided to tackle the job. In the months and weeks prior I had gathered all the parts together, so it was just a matter of finding enough time to do it properly and not rush.
The Ute went up onto trestles, and bits and pieces were removed to slowly but surely expose the inner workings of the head. There are various tools and techniques to do this job, but I was intrigued at trying a method which involved pushing nylon rope down the plug hole, and then turning the motor slowly by hand so that the piston would press the rope up against the valves. This would prevent the valves from dropping down once the retainers and springs were removed. (Another method is to fill the cylinder with compressed air). My brother-in-law came through one day to assist, and we worked through each valve, one at a time, first with the exhaust valves, and then followed by the inlet valves. I have the necessary tools to remove the retainers and springs from the top, but at the end of the day, we also had to improvise a little bit when it came to putting everything back together. There were some tense moments trying to get the cotters to seat correctly in the valves. Some pics below:
Rocker cover removed, camshafts removed, cam followers removed:
Valve Retainer and Spring removed (valve stem seals are the green bits in the pic):
Starting with reassembly, valve stem seals all replaced, springs and retainers refitted, cam followers installed on exhaust side:
Exhaust cam placed in position with new seal:
Intake and Exhaust Cams installed:
Timing marks lined up:
New water pump installed:
New cambelt installed (incl. all idler pulleys and tensioner):
New alternator belt installed:
Rocker Cover cleaned up with new gasket:
Spark plugs still burning nicely, will be reinstalled:
Closed up and ready to rock and roll again:
I must say, the first few turns by hand, as well as the first start are always a bit of a nervous time, but thankfully all was well. There was some smoke the first 10-15mins though, but this was probably greasy hands touching the surfaces which get hot and so on.
I also ended up rerouting my breather system (more aligned to OEM design now). After the first start was successful, I proceeded with an oil change and cleaned the air filter as well. The Ute was now ready to hit the road again.
June and July also came and went in a blur, but it actually marks 10 years since I carried out the conversion. I’ll have to check records, but its approx. 100000kms that I’ve done with the Ute in this state. It’s been a brilliant brilliant vehicle, definitely one of those “forever cars”. It’s still a daily (for when I actually end up driving these days), it can carry loads with little fuss, it’s comfortable, fast enough to annoy some more modern machinery on the roads and above all else, it’s fun. I look forward to many more years and adventures in my Ute.
Also, I’d like to note a quick shout out to all of those involved in my Ute build, maintenance and adventures over the years, with special mention: my wife and kids, my parents, my brother, Neil, Danny, Ross, Allen and Jabu.
In more recent weeks I’ve fiddled a bit with different car wash and detailing products on the Ute, but will post separate threads on that in due course. That’s all for now, thanks for reading.
gavsadler
Update Nov-22 to Mar-23:
The Ute has been serving me well over the past few months. Things did die down a bit in terms of requirements as a workhorse, although that will pick up again in the coming months.
In Jan-23, the Ute was treated to a mini-detail. I used a bunch of P&S Double Black products to try out, and overall I'm happy with the outcome. I have not come across a dud product yet. I actually can't remember what all I used at this time, but will make time to document this elsewhere.
For now, here are a few pics after the detail:
Moving forward, about a month ago, there was a motor show at the local school. So I registered for a spot and we went and put all the awesome microfiber, brushware and other detailing things on display. I also held a raffle on the day, so a box of things went off to the lucky winner as well. There was a great variety of cars on display, including a G OPC Hatch, Camaro Restomod, Chev Impala on Air, Shelby GT500, some Alfas, Ferrari 430, BMW 3.0 CS, and some newer machinery too. The food and drink stalls were also popular as it was a scorcher of a day.
Plans for the Ute in the coming months: more heavy lifting and moving as some home renovations continue. Maintenance wise all is good for now.
Thanks for reading.
gavsadler
Update Apr-23 to Aug-23:
This will be short and sweet, because quite frankly, there is nothing major to report on.
Over the last few months, the Ute has been working hard. This included shuffling building materials up and down from April to June, and then more recently some hauling of products to and from The Festival of Motoring, and then more recently, moving some bunk beds and other beds, as well as my brother-in-law using it in conjunction with a Venter trailer to move house to a new property in the deep south.
In June I did an oil change, replaced / washed filters and did some general checking - all is well, still running like a dream. I have noticed that the clear coat is starting to flake on the A-pillars, C-pillars and tailgate, so need to investigate further what I can do there. Maybe I rock the patina-look going forward.
But that is that, no expensive repairs, no major maintenance carried out. It still dishes out plenty of smiles and surprises.
gavsadler
Update Sep-23 to Mar-23:
Every time I post an update, I tell myself I need to do so more regularly, and then it doesn't happen. Anyway.
Not much news to report for the Ute. Over the past 6months it has been serving it's role well.
  • Weekly trips for some garden maintenance at another property.
  • More moving of furniture and household items between properties / storage units
  • This year I've started work at a new client in Sandton, so there is a weekly trip to Katherine drive as well.
It's still puffing a bit of smoke now and then, but otherwise running well. One issue did pop up in the beginning of the year though. My AEM Meth controller kept indicating a low fluid level, and as such, will not spray due to safety precautions. I thought it was the bottle fluid level sensor, so I tried to bridge it out, but the controller still showed low fluid level. This led me to believe that maybe the controller itself was faulty.
So I ordered a new controller and fluid level sensor from AEM in the States, and waited for that to arrive. When it did, I switched out controllers, but the new one also flashed a low fluid level warning. Damn. Swapped out the old fluid level sensor for the new one, and all was well, no more warnings. (So I assume there is some sort of resistor built into the fluid level sensor, so simply bridging it out was not a true test). I put my old controller back, and that too is operating normally, no more warnings.
I was happy that the issue was resolved, and I could return to some boosting again. What I had also noticed was that the Ute didn't seem to be pulling as strong on the high boost setting (reminder: low boost = 0.7bar on the wastegate / pump fuel, and then high boost = 1bar with meth injection on pump fuel). On high boost, the reading was only going up to 0.8 or 0.82 bar, so a little off the safe target of 1bar.
So one day, I decided to fiddle with the boost controller a little bit, adjusting the duty cycle up until target boost was met. It was set at 53%, so bumping it up to 63% saw the Ute hit 1bar on the first pull. I decided to lower it a little bit at a time, and now it's currently on 56%. The Ute hits about 0.9-0.92 bar now, so I'm happy with that, and I expect with the colder weather on it's way, that it will bump up slightly from that.
Other than that, all is well. My paint is still a question in my mind about what to do: full respray, flat and clear over the top to maintain some sort of patina effect, or do nothing and leave it for a while longer. I'm inclined to do a full respray though. I just worry that it will have a snowball effect and I'll want to replace all sorts of other panels and trim pieces so that everything is new.
Plans for the months ahead: service time, a few more shows and I would like to take it to one of the waterless skid pan events too.
That's all for now.
gavsadler
I forgot, I do have another update here.
In September last year after the heavy work of moving up and down, the interior was a bit grubby (long overdue actually). So I set about tackling cleaning of the seats.
I used P&S Carpet Bomber, and this, coupled with the Karcher extraction vacuum, did a great job.
Below are some before and after pics. Once the fabric was dry, I moved ahead with the leather cleaning and conditioning, again using P&S Xpress Interior Cleaner, and P&S Leather Treatment, Conditioner and Protectant.
Current update is that the seats are still clean, haha.
sash
Its a great feeling when the toy in workhorse clothing can excel at both :ROFLMAO: :ROFLMAO:
I didn't think the seats looked bad to start with..., but damn..., they look good now.
gavsadler
Update: June-24:
1 June was the BMW CCG's 1st skidpan of 2024 (delayed due to April school holidays). It was a fully booked event, with some old faces and some new faces, some familiar cars and some new contenders. I decided to take the Ute for a change, and get some FWD "practise" in sliding around. After all, it's been 6 years since I last did something similar in the Ute.
The weather was great, nice and warm, with a bit of a breeze to keep things cool. They've changed the route this year, being slightly longer with more twists and turns. while it looks simple and straight forward watching from the sidelines, I personally find it quite busy when actually driving, needless to say I got the route wrong on my 1st run, but managed to remember thereafter. Many others also provided good entertainment on their runs too (I'll point you to Benji's thread).
I managed to get a 1st place in the (admittedly small) FWD class, and 11th overall. There are some really good drivers attending these events, and machinery to boot.
Some media below from the day. More details and pics available here: BMW CCG Skidpan Autocross June-2024
gavsadler
Update June-2024 (continued):
I was spoilt at the end of June with some really nice birthday presents. A few years back, I sourced a 1:43 scale Chev Montana (the Brazillian version of our Corsa Ute). It's been sitting in the cupboard ever since. My intention was to build a replica of my actual Ute. At long last, the first step of the build could take place, that being the wheels and tyres. For this to happen, I had to get a donor Corsa D. My wife found one locally, and about an hour after blowing out candles that morning, I was busy stripping for spares, haha.
I think it came out alright:
It even has disc brakes on the rear axle now:
So next steps will be to blackout the bumpers and trim, and a few other bits too. Maybe some G Shift stickers as well. I guess this should be "Corsa C Ute - The Actual Toy Story"
gavsadler
Update Jul-2024 to Sep-2024:
Service time, it's been a year since the last service, with 7000kms covered. I changed the oil and oil filter, washed the air filter, checked plugs, and did a general clean of the engine bay.
I also decided to bleed the brakes as it has been quite some time since I last did it. I'm glad I did though, as it was looking rather dark and gloomy.
Other than that, the Ute is running like a dream with no issues. I also hit a mileage milestone in July:
In September, I exhibited my wares at the Festival of Motoring @Kyalami, so the Ute was hauling trailers up and down for the best part of a week. Unfortunately I had an incident where I hooked the front left rim on a curb (I blame poor planning to get to/from our exhibition spot, so I had no option but to try reverse a trailer through the tunnel going under the track. Anyways, it can be fixed, so I will probably get that done in the next few months and also look at putting fresh tyres on.
Future plans for the Ute, I'm contemplating a respray, but that is a costly exercise, and as mentioned elsewhere, I need to curb the spending a bit.
That's all for now though.
gavsadler
Update Jan-25 to Jun-25:
At the beginning of the year, the front-left wheel bearing decided enough was enough, and made itself known through an intermittent clicking noise which sounds like the CV joint is on its way out. Thankfully this was not the case, only the wheel bearing, so I parked the Ute and stripped everything off. The steering knuckles and hubs were sent off to Uncle Al, where they were “out of sight, out of mind” for the best part of 6 weeks. I wasn’t too concerned though, as I was thoroughly enjoying the 130i during this time.
Anyway, I eventually got the knuckles back, with new wheel bearings and hubs pressed in. At the same time, I decided to replace the tie rod ends. I reinstalled everything, and took the Ute for alignment as well. The tracking is much improved, but when doing the alignment and balancing, this also uncovered another inevitable issue: buckled wheels. Every single wheel is bent, to various levels of concern. They balanced as best as they could, and fitted the worst pair of wheels on the back. The plan would be to keep going like this for a bit, until such time as I get the wheels refurbished, and will then fit new tyres all-round as well.
New tie rod ends:
New Hubs and Wheel Bearings:
Fast forward to June-25, and I hit a new mileage milestone: 260000kms.
It was also service time, so got the necessary parts and spent a few hours working through things: new oil and oil filter, cleaned the air filter, new cabin filter (this is a stark reminder of the dust and pollution out there). I also decided I wanted to check the spark plugs, and switch out back to the Iridium plugs I used previously. It’s been some time since I ran these, so I wanted to see if I could notice any significant difference. Pulling the coil pack out, revealed what seems to be another common perp in the form of a leaking tappet cover gasket. The plug wells of cylinders 3 and 4 had some oil in, so this is another item added to the future to-do list.
I also noticed that my coolant seemed a bit low, and 2 days before, noticed a drip in the driveway. I didn’t think too much of it, as I know sometimes one hose does perish after some time, and then cause a slow leak. I inspected the hoses but they all looked fine. Anyway, I topped up coolant, with intentions to monitor going forward.
3 days later, on the maiden voyage post-servicing, I was heading to work, but had to stop to fill up with fuel. The attendant said he saw me pulling in, and that it’s leaking under the car. Oh no. I had a look, and it looked like a hand shower was activated behind the motor. Coolant bottle empty. Damn. I did some more searching, and came to the conclusion that the oil cooler (which sits at the back of the motor, behind the intake manifold), had given notice. I waited for the motor to cool down, topped up with water and then limped back home (thankfully I wasn’t far, and no traffic in the opposite direction meant the motor didn’t even warm up enough to cause pressure build up and subsequent coolant loss.
A new oil cooler and intake manifold gasket was procured, and then over the course of the Father’s Day long weekend, I set about stripping everything off, cleaning up, installing the new parts and then closing again. Inspecting the old oil cooler, there was no obvious signs of catastrophic failure, but I suspect it was the lower joint between the 2 oil feeder pipes which had split. Under pressure this would then allow for the leak (or rather more serious shower on the day).
With everything installed again, the Ute has been running faultlessly again. It’s still a hoot to drive, and is serving me well on the highway drives to and from Fourways and Sandton a few times a week.
Plans for the short term are to send the wheels in for a refurb, and then fit new tyres. I just need to juggle a few other car-related matters and events at the moment, meaning the Ute is my primary mode of transport for July.
That’s all for now, thanks for reading…
