Project E46 330i Touring
evnmopwr
Nothing like blown coolant lines on a Saturday afternoon when The is no chance on getting parts till monday.
Thankfully i was home when i saw the puddle on the floor
the 1 was brand new line i installed when engine was rebuilt (one that runs along the head)
The other i thought i replaced too but seems no invoice found for it.
I will be replacing both again just for peace of mind.
Will tear into her today and pull the intake.
Will use the time to install the new stearing rack boots too thats been on the shelf for some time now.
evnmopwr
Teardown started
Intake off
And my guess is the new coolant bottle and new 2.0bar cap preasured system nicely.
and this pipe backed out??? Not sure if you can see, but the 1 O-Ring is clearly visible. it like it backed out 1cm or so.
bare in mind, Since the rebuild, 19000kmish i replaced the bottle and cap.
Its been 100% ok up until i replaced these 2 items. since then i needed to top up.
Thoughts??
Will order OEM pipes tomorrow from dealer.
hopefully this fixes it as i dont want to take this intake off again
evnmopwr
Also I either Found a tear in the upper intake boot or i caused it while removing it and the Vanos line is leaking
so that needs replacing tomorrow too.
2 x Plastic Coolant pipes
1 x Upper Intake boot
2 x steering rack boots
1 x Vanos Line
BMW and their biodegradable cooling systems...Add OFH gasket to the list...I found it near impossible to get that coolant pipe installed with the OFH still installed. For the effort saved and the peace of mind of a new OFH seal, it is totally worth it, even tho you probably did it with the engine rebuild
evnmopwr
BMW pipes have been ordered.
Decently priced. 1 problem, Its JHB only so i have to wait.
Red Rubber Grease, Motul coolant and New upper intake boot is on its way.
just the vanos line i need to go scratch out as i had a new one in stock. i just dont know what i did with it
im going to remove this el-cheapo part later to see what the issue is with it.
evnmopwr
Red rubber grease bro. You will never have issues with these quick release pipes again!
evnmopwr
O-Rings looks compromised?
they not as puffy as the OEM ones it seems.
and this pipe was in for around 19000km. :|
Dont make the same mistake i did. OEM for these parts ONLY
