Sirhan said:
and it is also
lower on power than the standard e46
but for some reason ... faster in a drag than the v8 e92 ..... dependent on driver? :thumbs:
What gives you that idea?
On average the Z4M produces slightly higher wkw figures than a stock E46M3, but partially due to the shorter 6 speed box.
For arguments sake even if the Z4M produced 5kw less due to exhaust that's less than 2% on the fly and won't be noticeable anywhere. 15 degree temperature difference will have more effect than that.
From what I've seen on M5board the CSL > Z4M and then again the V8M > CSL so unless the E9x M has more occupants I don't think it will take a Z4M.
However I have not tested this myself...
Edit
Your Z4M is faster than a E46M3 so why complain?
Anyways what you're referring to is theoretical only. ACTUAL flywheel figures are identical and wheel figures should favor the Z4M anyways
