WORLDS FASTEST SUV
Prev
Administrator
With 900 HP and a top speed of more than 330 km/h, G-POWER is building the world's fastest SUV based on the BMW X6 M in a limited edition of 5 units.
With the G-POWER X6 TYPHOON RS ultimate V10, G-POWER once again presents an automobile that can only be described with superlatives. The standard X6 M with its twin turbo-charged engine is already powered by an impressive power unit, but the standard BMW engine has not been capable of arousing emotions to the same way as the original M-POWER engine has been able to up to now. For this reason the engineers at G-POWER decided to fit the X6 M with the breath-taking performance of Formula 1 technology.
An appropriate power train to suit G-Power’s philosophy was quickly found. A high-revving engine with direct throttle response is now showing a character which the 5.0 l V10 power unit produced by M GmbH inherited at birth.
The inner workings of the 10-cylinder, four-valve engine are optimized by light, precisely balanced MAHLE high-performance forged pistons with lower compression and increased mechanical strength. As the standard connecting rods and piston pins were equally not up to the considerably increased forces, here too, recourse was had to special parts. The forged, 7-bearing crank shaft is also a custom-made part which boosts the cubic capacity by 10% from 5.0 up to 5.5 litres. An optimized data map for the engine electronics rounds off the extensive modifications made to the V10 power train. The result is a peak performance of 900 HP / 662 kW at 8.000 rpm and a maximum torque of 870 Nm at 6.800 revs. This enormous power output is transmitted by a six-speed gearbox built by G-POWER to the rear axle. The automatic gearbox fitted as standard, just like the standard BMW xDrive all-wheel drive system, have been sacrificed to the G-POWER engineers' objective of creating a pure-bred sports car in SUV clothing.
Powered like that it is an easy job for the G-POWER X6 TYPHOON RS ultimate V10 to claim the title of the fastest SUV in the world: The sprint to 100 km/h takes a mere 4.2 seconds. In less than 13.0 seconds this exceptional SUV is already up to 200. The top speed is over 330 km/h.
rick540
Awesome, I like
Pity they put the red "ultimate" in there, spoils it, sounds like a brand of cigarettes.
Apart from that I really like the interior....rad
JustNN
:dropjaw: i would of left the standard M kit on cause its sick and just put that monster engine in, just my 2 cents
