NBN said:Did you buy this car off a forumite? Please post up pictures of your oil filter?
Hi there I'm not sure if the owner of the car is on the BMWfanatics forum. Herewith the pics
NBN said:Based on your previous posts it doesn't look like you drove the car hard before the oil got up to temperature and you also mentioned how you let the car cool off. So could it be that someone sold you a lemon?
What's your plan of action? Have you contacted the dealership you got the car from? If the car is financed etc, will they assist you in returning the car etc etc?
Jeremy said:Eish bud, I hope you get it sorted soon and that it isnt a major repair.
Let me know if you need any help from Jhb, like checking parts for you etc, im in the east rand, so if you find anything on this side, i am more than able to assist if you require.
MedicN54 said:I'm thinking of just getting another crank one time sometimes engineering work can cost more than getting a good used one. Also if the crank is that bad I would not be comfy with a cut crank. With the luck that I have had now, I don't want to take any unnecessary risks.
NBN said:Why not wait until Monday to hear from the finance house legal department.
If the previous owner doesn't answer your calls, maybe you need to pay him an unexpected visit at home, where im assuming you collected the car...
Without knowing facts, it does look like you were sold a lemon, I'm not a vindictive person, but i wouldn't let the previous owner get away with this so easily
Gordvisr said:Hallo, hope you get it sorted, with my personal experience regarding rebuild, this would be my advise.
Strip motor completely, Send Pistons, block rods and crank to a reputable engineering shop to measure all for you. Rods should still be safe if it was not driven for long with the bearing failure, but possible it has to be resized or replaced. Depending on your mileage/regular services with correct oil and all pistons and block should still be fine, Crank might need to be cut or replaced, I would not buy a second hand one for the main reason, you would not know if the crank fell or ..... up untill you had it on a bench, tested for this. Rather cut, if it does not need to go more than 20 Thou you should still be safe with grinding the crank. Use new bolts on the rods, DO NOT USE THE OLD ONES, peterAEW here on the forum might also have good advice on the rebuild.
KPM_330 said:Sad to say, seems like the previous owner knew something was up, threw in thick oil to 'slow' the effect of deterioration and sold the car.
I hope I am wrong but that is how it looks from the outside looking in, especially seeing as though this car was hardly driven, by your admission.
