it will take 2-6 weeks if i order next week... if thats fine i will place to order...
ok could not find anything wrong with the piping the pump must just be a bit noisy... at R1650 i guess i should not be surprised...
i need a pump quick no i got this one... if you want a quite pump get the oem Luk pump i was told by a mechanic that you should expect to pay about 3k for a good pump the steelers want 9k so dont even bother getting a price from them...
the LUK LF-20 is the round back found on most e46 and
the LUK LF-30 is the flat back found on early face lift models
the LUK LF-20 is better because you get better feed back but you will have to change the pipes and brackets to fit it...
