Henry said:Hope you find one. Whats the mileage on your car.
herr bmw said:thats a bad one,glad you brought the car safely to a stand still.
ive seen how you like taking corners and could have gone very wrong
Sankekur said:If the pulley can still turn then you should be able to drive the car, you will just have a hell of a time trying to turn the steering wheel.
From what moranor described it would seem that a part of the impeller or something broke off inside the pump and jammed the shaft and preventing the pulley from turning, in this case I don't thing you would be able to drive the car for very long, as the belt would probably giving quickly due to the friction, and this would very bad as the waterpump is driven from the same belt. So can and could have been very bad indeed.
Coisman said:imp:
Moranor, you would just go and do anything to get out of a race with me!!![]()
herr bmw said:cois,ive seen moranor drive,we traveled the same route after saying good bye and he diappeared,he loves corners
moranor said:that just means you need to come down more often![]()
moranor said:pump is fitted and is working great... but it does make more noise than the old one... maybe i should look at getting a better pump...
DROP IT - ZN said:Moranor did you get the pump from Martin's?
Philip Foglar said:moranor said:pump is fitted and is working great... but it does make more noise than the old one... maybe i should look at getting a better pump...
That's odd! What brand and type did you get? Did you DIY fit it too?
