msm@Promotec Performance said:Nice article here too: How to Compare Weight Savings to Horsepower Gains
Lots of information and methodologies have being discussed at length but for the purpose of this thread lets discuss further findings , formula derived from Tuner University.
///Shaun said:So now that this thread was typed out and explained , anybody out there tried and tested this explanations.
Any feedback guys ?
Does it work or not for you?
Any feedback guys ?
Sareshan said:Thanks for the Tips Shaun,
I tried it with my 330d at Tarlton a few fridays ago... and managed to do a 14.3
Launching in 2nd gear makes a huge diff compared to how i use to launch in 1st gear....
:thumbs:
S1NGH 001 said:///Shaun said:So now that this thread was typed out and explained , anybody out there tried and tested this explanations.
Any feedback guys ?
I've tried it out, and it worked very well:rollsmile:
Thanks buddy you're the man :joy:
bmsportzn135i said:So would a 2nd gear launch in a x35 manual also achieve better results. As i seem to be suffering lots of wheel spin, even with a set of hossiers and low pressure!
Josh-ZN said:bmsportzn135i said:So would a 2nd gear launch in a x35 manual also achieve better results. As i seem to be suffering lots of wheel spin, even with a set of hossiers and low pressure!
135i - if i launch in 2nd gear i will get left in the dust. not enough oompf in 2nd from a standstill for me. if i launch hard in 1st, i spin my wheels like the road runner cartoon :dunno:
solution: A45 AMG. launch like a mofo in 1st and hold on tight :fencelook:
UpNcOmiNg! said:Launch is possible with a rwd, I successfully launched with an RS3 using launch control with my car. Just takes some playing with the throttle and getting that sweet spot.
///Shaun said:Section 4 - “Weight loss” to “Horsepower” Formula
Old weight (3500) / New Power-to-Weight Ratio (15.81) = 221.38 hp
So that means that by taking 100lbs out of the 3500lb car, we would have had to gain ~ 6.38 hp (221.38-215, (the new-original horsepower) to accomplish the same thing WITHOUT taking out the 100lbs. Thus in this situation, 100lbs is roughly the same as if we had done something to gain 6.38hp. So to some extent, this means that something like an intake that adds +6hp would FEEL kind of like losing 100lbs (or a very skinny passenger) in this particular vehicle. In another car with different weight and power numbers, this figure would be different but calculated in the same way.
CliftonH said:Hi shaun.
I am used to the launch in first gear. It worked on some launches and others the car bogged down.
I tried it on 2nd gear and I was just burning clutch. Did everything the same as when I launch in first gear.
On 2nd gear the car was just rerving but going nowhere slowly and at abt 6 seconds later it takes off. Like the clutch was not realing when I left it.
I tried it twice and both times it was just riding clutch.
After that I just parked it off cause I could smell the clutch bad.
moranor@axis said:CliftonH said:Hi shaun.
if you have to be slow on the clutch to stop it from stalling then it would be better to launch in 1st... and regulate to wheelspin/bogging by having the right RPM...
