The unlikely donor
Sankekur
Thanks gents really appreciate it.
With the subframe out also removed the prop shaft and gave the underside of the car a clean (or at least the portion where the subframe goes)
uc
https://drive.google.com/uc?id=1c1EPnZ2EnHdI4zbCDTfeIUxmicguRYDc
uc
https://drive.google.com/uc?id=1HYkmFRl7JyJ0i_i6Wh08SVj0vaHZbRYN
uc
https://drive.google.com/uc?id=1LhYqJeFFJf0lw3PyQfAQn8GlGMeXz8v-
uc
https://drive.google.com/uc?id=1aMsfbcGJ1y1tEAPCOgIX-bGX5vLzHVYc
Fitted the new subframe rear mount
uc
https://drive.google.com/uc?id=1fvkbMUJaLRGWtzZFKJ39-ZCpKwL8drl2
And refitted the rear subframe
uc
https://drive.google.com/uc?id=1qypgTQrmRMuTKjM9I8anyw1ZW5NbAQgj
Fought the diff back in
uc
https://drive.google.com/uc?id=1ZYjMCeJwcayZ9_Ic2xVyonnjGeQ0cvK0
uc
https://drive.google.com/uc?id=1tTiKUNHlxk-NeQ9NymsC-UHtR539xmDD
Cleaned the rear anti-roll bar
uc
https://drive.google.com/uc?id=1hMT4HuYXqU88fRgwZKHVPcsrpR19NyVd
Removed the end links and refitted
uc
https://drive.google.com/uc?id=1T1T4sm08ZPXostHu4vZP6FPkULwc2Lvh
Fitted new end links
uc
https://drive.google.com/uc?id=1CinBCwY2V8QLxPVSugMotelKss25_3Yb
Refitted the trailing arms
uc
https://drive.google.com/uc?id=1jMTwjY10PZX-EQC7OqKvLfYTnZQeO31N
uc
https://drive.google.com/uc?id=1SvvLm8Kqx6NvXNbbG7sPy4BMSgt8od5t
Thanks for watching.
Loom
Nice work. For the subframe, diff, etc. - did you reuse the old nuts and bolts?
Did you pre-load the new drop links? Just asking for curiosity's sake.
Sankekur
Thank you.
Yup I reused all the old bolts and nuts, they are still in pretty good condition, some surface oxidation but no corrosion.
No pre-load as of yet, plan to install everything and then do it all at once.
Sankekur
Removed the inner bearing shell form the hubs
uc
https://drive.google.com/uc?id=1SurK7Vem6-dCf15vhOil_H_SXngFjR9f
Cleaned and refitted the hubs and drive flanges
uc
https://drive.google.com/uc?id=15ioT1SDMCLPLji_XCcEY7O8XNFzF8EWz
Stripped the side shaft CVs
uc
https://drive.google.com/uc?id=15wLFyTKDCZjsML8wsAS_ibHq3pWisaMR
Cleaned everything
uc
https://drive.google.com/uc?id=1s_IbekuG_FdC2PsA2zvgPSUzSpGogy6t
uc
https://drive.google.com/uc?id=1Gzts3BHowrW8chd5LuEIIUuP-A-7j3yd
Dry reassembled the CVs
uc
https://drive.google.com/uc?id=1eiXCTf52URpsTpcgHfjcdu626Ln3AgzA
uc
https://drive.google.com/uc?id=1quMFQuTPFmLAgfGTU9ry_ZQ8WayKviam
Reassembled the side shafts left
uc
https://drive.google.com/uc?id=1gpUsaiXMnrVy5mDfTiKv7irBejqdGz6S
and right
uc
https://drive.google.com/uc?id=1EMt8txQ-awv7kUHE8xx9yrUH9hsjNqhD
Knocked in the hub nut locking plates
uc
https://drive.google.com/uc?id=1kq-BE9hq9BMvbl2h_A5qlvfBF3fNt5Z7
Refitted the side shafts
uc
https://drive.google.com/uc?id=1Q8lO_VmGx-m8IfGJjSVLSN6LUwV1jN4c
Cleaned and refitted handbrake parts
uc
https://drive.google.com/uc?id=1T9zvleRt1vPip6KybmeE019Luk6zRLLv
uc
https://drive.google.com/uc?id=11THtzBCZPJMXyPxlPz1uXQ2i67p3N9fD
Refitted discs and caliper carriers
uc
https://drive.google.com/uc?id=1x4PMHKtfTNeZ9lvCwOkMBuyqBRMZX6WV
Refitted calipers
uc
https://drive.google.com/uc?id=1heSoQZKwPGQqaRZJNQy8KtstqXMxwFKH
Refitted brake hard lines
uc
https://drive.google.com/uc?id=1jMsjs25_ZhhQENT8X4zUYkOHeheIluU6
Fitted new rear pitman arms
uc
https://drive.google.com/uc?id=1eIsVWCujLakCVLuaQLGA_xlpVWj7a6JH
uc
https://drive.google.com/uc?id=1PWFkDEX1alcuECxy3Fc6CLbj9XFF9ysM
Fitted braided brake hoses
uc
https://drive.google.com/uc?id=1jCo-fZK-EJ6jMBz1P76K7Mx-KPq_Dp9F
Fitted rear struts
uc
https://drive.google.com/uc?id=1taAhp_wgctUVmurqvZaTXrpv1LzDjs18
With the struts in I pre-loaded the rear suspension, bled the rear brakes, adjusted the handbrake, and refitted the prop shaft heat shields and exhaust.
Benji
Bit of a thread revival, but what happened to this project? Love the work you have done but it gives me the shivers as I'll have to do all this (and spend the money) for my 540i/6 soon
Sankekur
The suspension rebuild is done, currently it is sharing daily duties with my M3 while I finish up work on the 330i.
Next up (though this is always subject to change) is a rebuild of all the power steering hoses.
Benji
Good to hear she is back on the road, what suspension setup are you using and how is the ride compared to stock? I also need to tackle my power steering hoses, but for now its easier to just top it up every other month :rolleyes:
Sankekur
Thank you
H&R springs with Bilstein B6's, I would say the ride is very close to stock it is complaint enough as a 5 series should be but not overly so.
Apart from this front is mostly Meyle parts (will see how they last), rear pitman arms are also meyle. ARB bushes and trailing arm bushes are poly, and the rest of the stuff is OEM.
Riaad
Events Organiser
Whats happening on the 330i :rolleyes:
