I ran 270 on the 1km on Stock Michelin's from the factory with full interior. So yeah, running a 1km should show the power. I'm sure it will run over 280.
Thats very quick bud, what people dont understand is that on the highway doing 120 obviously and then thumping your car as hard as you can see how long it takes you to 200km/h and then try understand doing 270km/h from STANDSTILL! Awesome exit on a stock type car doing the 1km:thumbs:Sherwin@xcede said:I ran 270 on the 1km on Stock Michelin's from the factory with full interior. So yeah, running a 1km should show the power. I'm sure it will run over 280.
Twinz said:@extreme-eg
Sorry but you have to introduce yourself in the showroom...your posts could be construed as advertising or just someone stirring...
:nonono:
moranor@axis said:problem is even if it does not set the times expected 1st time out it proves nothing because traction will play a big role in this...
im pretty sure whatever the outcome is the haters are still going to find an excuse to hate... its what Haters do...
George Smooth said:I don't think the Savspeed guys need to prove much in terms of reliable build and power output etc. Running times on the quarter is a different kettle of fish especially with a very powerful car. I don't think the drag guys are hating they just know the ingredients it takes and to run sub 11's and power plays a smaller role.
extreme-eg said:SDP said:You need about 650 hp to run 300 on 1 kilo in a 1400-1500 kg car
I believe more....(remember your car is run on Budler's low reading dyno)
ed_z said:Turned boost downraise: What from 2.2 Bar to 1.7 Bar?
raise:
George Smooth said:moranor@axis said:problem is even if it does not set the times expected 1st time out it proves nothing because traction will play a big role in this...
extreme-eg said:I hope this hyped up Z4M actually pulls off some numbers at the track to back up the horsepower claims...
290+kph on the 1km sprint and 10 second quarter miles is where it needs to be, otherwise it will just be another "claimed wonder child"
SDP said:ed_z said:Turned boost downraise: What from 2.2 Bar to 1.7 Bar?
raise:
lol not quite my Turbo is maxed out @ 1.8 bar I ran that on 1.5 bar. I was playing with the gearing for the next attempt and went slower.
38 Lafras du Plooy BMW 325iS B 300
39 Shaid Essop BMW 325i B 297
33 Sergio da Costa BMW Z4 B 276
37 Yunus Goolam BMW 325iS B 263
5 George Anagnos BMW M3 B 258
47 Sav Gualteiri BMW Z4 M Coupe B 240
I'm the 2nd guy, the no 1 position is also a 328 Setup like mine biult by Budler Motorsport
That was with a boost leak!:bangdesk:UberTaner said:Very nice!
I remember Sergios one making 620whp at KAR - wonder what this one will reach given its got a little more hardware under the hood.
I 100% agree with your quote but the run was supposed to be from 2nd gear from the roll and the Z4 didnt launch as described on the vw post.Sherwin@xcede said:Racing isn't about worrying what's gonna' be posted on net. I remember cruising with my 325iS turbo & knowing it had issues with the clutch. But you come to a traffic light & a fast car is next to you & you run him. It's not about ego's and what goes on the net. It's about being a petrolhead & having fun & enjoying your car. Real petrolheads will race anytime, anywhere, car broken or not & not care what will be posted on the net.
Having said that, the RS3 is an 11 second car & will probably beat the M coupe over 400m whether the M coupe is perfect or not. And Mooloo is a gentleman so he would not brag about beating a wounded tiger.
UberTaner said:wow - thas a lot of juice there.
Is that the dyno of the silver z4m?
What is the power difference between that car and the original matt black z4m turbo Sav did?
Sherwin@xcede said:ed_z said:What did your charged M3 do on the 400m?
My best to date is 11.2 with a best 400m exit to date of 208. My best 1km is 270 running into the speed limiter at 941m.
If my memory is correct Sergios Z4 ran 211kph 1/4m at odi @1.2 odd bar boost and was cutting out at 6k(1st-3rd)and he still switched the car off and on for about a second in 4th to clear all the faults and only then did the car get going.On the 276kph run he was only doing 198kph on the 1/4m so work out the calculations and thats 289!Sav told me that the car was already doing 276 at around the 900m mark and was limiting and cut out from there on!I think his car would easily run a 220+1/4m without the cutting out issues that said the budler cars cleaned up,well done guys!Sherwin@xcede said:I ran 270 on the 1km on Stock Michelin's from the factory with full interior. So yeah, running a 1km should show the power. I'm sure it will run over 280.
JapScrap said:extreme-eg said:I hope this hyped up Z4M actually pulls off some numbers at the track to back up the horsepower claims...
Agreed, however it sounds like 10's may not be on the cards but the exits definitely. 220'ish on the 400m as well to be expected.
Im keen to see how this car does. Has definitely been hyped up and the dyno figures seem to back up the hype. Now to put something down on the tar.
ed_z said:Finally some inside info on the Savspeed monsters thanks bud!
SDP said:extreme-eg said:SDP said:You need about 650 hp to run 300 on 1 kilo in a 1400-1500 kg car
Yip but on the run I turned the boost down to get the car not to wheelspin too much so thats why I estimate 650
[video=youtube]
Did you turn the boost down only for the launch and then up while on the move?I have been told by a couple of people that you guys are running well over 2 bar,whatever the case these 328's are very very quick and made the Nissan boys extremely nervous,they disappeared quickly after the 300kph run.SDP said:extreme-eg said:SDP said:You need about 650 hp to run 300 on 1 kilo in a 1400-1500 kg car
[video=youtube]
My Build tread
BuildI remember reading a post a while back from a Toyota driver saying that BMW's are crap and will never run with the jap cars,you guys proved them wrong!
