Kobus325is said:moranor@axis said:well the write up on diesel boost says:
Restores and boosts power & performance, improves acceleration & throttle response
Helps remove hesitations
Increases cetane rating of diesel by up to 5 numbers
Cleans injectors and entire fuel system
Removes deposits from combustion chambers, extending engine life
Reduces carbon formation, extending oil life. Cleaner oil means less wear and tear on the engine
Reduces diesel smoke
Improves cold starts
Reduces harmful emissions
Improves fuel economy
Adds lubricity to low sulphur diesel, lubricating fuel pumps and injectors
Protects engines and turbochargers - even when used with high sulphur diesel
Inhibits corrosion
Treats 1 tank up to 100 litres of diesel
Non-Flammable
with it treating 100l it definitely seems to be the best deal of the lot :rollsmile:
:thumbs:
So a can of this on every tank of diesel should do the car good ? Is there also different octane ratings for the diesel ?
only one flavor for now but judging by evangelical preaching done by most diesel owners on this forum they will have to make some more flavors soon... It treats 'up to' 100l so mixing it with less fuel should make a stronger mix I will see if i can get more info on this...
'It says Continual use will increase engine power and economy' so i would think yes you should run it in every tank
