'ruin' lol no i think it makes the thread :rollsmile:
DreamerM6 said:
moranor@axis said:NF race 6 Ron (black bottle) is the only boost not recommended for use in every tank... it is made for special occasions and will cause problems with use in every tank because of buildup... all the others are designed to be used in every tank and will not cause problems...
if you need 6 Ron on every tank you can use the Ultra Race concentrate on 60l...
using NF Ultra Race concentrate at full 10 Ron mix is also not recommended for every tank but 6 Ron and 8 Ron can be used in every tank...
How to find the right octane
Rommies said:moranor@axis said:NF race 6 Ron (black bottle) is the only boost not recommended for use in every tank... it is made for special occasions and will cause problems with use in every tank because of buildup... all the others are designed to be used in every tank and will not cause problems...
I'm confused at this part???
Oh wait....
So you don't recommend Race 6 Ron in a everyday commute, but 6 Ron Ultra Race is safe at every tank?
moranor@axis said:R 210 a bottle
16 in a full case will give them to you at R 190 if you want a full case and will pickup at Axis Engine Works :rollsmile:
///Moose said:Hey Sean, Im keen on some DIesel Clean or boost as well as Ultra if it will be any good for the M? But priority for now is the Diesel NF
outlaw335 said:Everything has gone up,everything.When the price of NF hasn't changed,you know theres still hope left![]()
