M5 upgrade
Beast_Power
M5 Ettiene said:
Having a power pulley installed, rev limiter raised with software mapping, and secondary cats removed.
What Pulley are having put on and what is the cost of the pulley ?
Fordkoppie
IF the crank pulley is detachable form the damper, it should be ok, however, if the damper is dumped you will snap the crank eventually.
s62 engine have hydraulic lifters, hence the 7000rpm limit. Don't go over that!!!:nono: unless you plan on converting to solid lifters + matching cams
M5 Ettiene
What has been done:
Eisenmann Race Exhaust & K&N filters, Evosport Pulleys fitted, decatted the primary section of the exhaust, remapping, raised the rev-limiter to 8500rpm, removed the road speed governor. Raised the torque limiters & optimised the fuelling, timing & VANOS parameters.
The total gain on the wheels was 40kw (54hp) & 53NM. And the total gain on the engine was 62kw (84hp).
What can I say the guys at Xcede know what they are doing. Thanks Sherwin
Graphs + vids
http://www.xcedeperformance.co.za/2011/03/v10-m5-power-gains-at-altitude/
Mamba
you will need to keep an eye on the conrod bearings with the rev limiter raised. Do you know if rod bearings have been replaced before? what kilos on the car?
Sherwin@xcede
Hi Mamba, this is a V10 M5 so it's not affected by the conrod bearing issues that plagued the E39 M5.
Mamba
I should have watched the video before trying to make a wise comment....:hammerhead:
good luck with the mods...;)
