Trev24 said:
Thanks a lot guys . So is it better if I go custom ?
Also im from durban . Any places that you guys know over here that can do the stuff for me ?
well if you making all the effort you may as well just get a set made vs forking out 14k for a set of shrick cams
These are the specs of the shrick cams tho, Im sure old dutch racing can do a custom grind, they do have a 1000hp E36 so they know what they doing :rollsmile:
Cam Specs:
Intake - 264 degree, 11.2mm lift
Exhaust - 256 degree, 10.6mm lift
just be prepared for other expenses that you may come across, you also looking at an estimated R300 per lifter x24 for oem . I would highly recommend changing these if your car has high mileage.
Furthermore you have a vanos engine so I would get the seals replaced while you getting the cams sorted :rollsmile:
