ariesone
Hi all,
I seem to be having some troubles lately. I have a 323i 2006 e90. My problems all started when I noticed that on some occasions I should have idle issues. I checked the DISA valve on my intake and saw that there was not flap in place. I assumed that the previous owner removed the flap if the unit was faulty. Anyway, I purchased a second hand unit and the car seemed to run fine for a day or so. Then, I noticed that the car started to misfire and there was a knocking noise coming from the engine. The knocks increased with revs. Upon further inspection, I noticed that it was coming from the valvetronic motor.
The first thing I looked for was air leaks but could not find any. So I pulled the intake manifold off to have a better look and found the broken flap from the first disa valve. I could not find the pin however. I have changed the gaskets on the intake and the throttle body.
Another issue though... when I ran diagnostics on the new disa flap... it did not open or close so my question is, if I was running the car with the disa in a closed/blocked position, could it have caused damage or a vacuum leak somewhere. What should I look at next. Please note that I have changed the breather hoses to the oil separator..
Your input is much appreciated.
