bmsportzn135i said:
Thats one of the reasons why im trying to avoid eth!
The flash for me like twinz said allows me to run higher concentration of eth. Recent reserch indicates that the stock pump is good to around 500bhp provided you runing meth.if you want bigger numbers you need to upgrade the pump.
For me the flash just deleted all those troublesome 29xx codes. They really a pain.
An upgrade of the pump allows for less pressure drops in the fuel pressure. If your log indicates that the pump is droping below 40 than the possibility of actually having an actual hardware fault on the pump is greater. But you will get a code and if you already tried adjust opening loop fueling than definately its hardware.
If ur car is making more than 440 HP than I would suggest upgarding if not your OEM one is fine.
That will be my final mod.
