Hi guys done some work made a list of all the issues. It's so bad
Most of the stuff has been sorted.
*Untuned
*Leaking custom sump
*Missing 120i ecu
*Butchered engine Harness
*Flywheel not balanced
*Flywheel not skimmed
*No dowel pins on flywheel
*No dowel pins on gearbox adapter
*Gearbox adapter not skimmed or straight edged
*clutch disintegrated
*pressure plate needed replacing
*exhaust made from 8 pieces including mild and stainless steel. Had small and big pieces restricting flow
*exhaust leaking
*electrics not working i.e. Cluster. Climate control. Rear windows (front windows opened with key).
*2nd gear touching propshaft
*high pressure power steering pipe leaking due to it being cut and joined
*fuel leak where the connection of the Lexus v8 fuel line was. The pipe had to be replaced as it was too hard to seal correctly
*airfilter extremely dirty
*diesel Diff with a ratio of 2.56. Upgraded to a 130i Diff of 3.46
*shocks don't function anymore
*rear brake pads metal on metal
*rear brake rotors hairline cracks
*front brakes have a shudder and rotors need to be replaced
*brake lights stay on
*fog lights broken
*throttle cable broke as it was installed at a 90 degree angle and cable tied to the pedal which eventually snapped
*bumper air dams misaligned
*washer fluid bottle removed
*radiator loose
*radiator fan (has 2) both are set to pull so they are pretty pointless at this point
Radiator behind plastics so airflow was restricted
*radiator needed a overfill bottle but instead an expansion tank was used. So none of the water from the radiator could be sucked back into the system after it reached boiling point
*spark plug used to block hole on power steering pump
*ac system removed
*heater valves not connected
*bonnet not catching correctly
*fuel flap not flush on body work
*wheels not balanced
*missing center brace
*bumpers aligned
*bonnet dented
*needs boot and bonnet shocks
*clutch bleed nipple broken off
*fan cowel missing
*seized left rear caliper bushing pin
*torn front fender liners
Anyways so the diff is in and man does it feel great we out in a 130i diff which is 3.46 and it feels nice and strong !
So I removed the water bottle it's purpose was a water catch tank. It was suppose to have a overflow bottle with a pipe going to the fluid incase it was needed it was also sitting much higher than the radiator. So I removed it and bought a corrolla bottle to replace it.
Now the radiator. What a mess. It has an aluminum one but is sitting higher than the air ducts so it's getting very little flow and to make it worse it has 2 cheapie fans connected to it and they are pulling air so it's really useless !
Bought a proper fan and getting a custom cowl made and I am going to move the radiator further forward and lower it for more flow
Check this they used a spark plug to close a hole lol
So another issue I have is that there are major leaks as the oil pan was custom made and it looks like it was done with a stick welder the sump plug is held in with silicone. Lol
Power steering is also leaking as the high pressure pipes have been cut and joined and clamped which is causing it to leak like crazy
I also upgraded the brakes to 335i calipers with axis v2 guides and new rotors and pads
18" Equip reps
The rears were also replaced but the right rear caliper guide was fused so the caliper was pretty useless. Going to replace that
Difference in pad size
Thinking of modifying this planting as my radiator flow is being affected.
More to come soon...
