How to build a 120i e87
Captain_Stealth
Hi everyone so finally sold the shell. Will post a breakdown of what I eventually got for everything although I do have a few parts left which I recon is worth around 5k.
So sold the shell finally after months and many time wasters.
Captain_Stealth
Here is the break down, crazy to think I was getting offers of 20k and 30k in the end strip and sold parts for R144 570.00 with around 5k of parts left. I have kept the buyers names out of the list. The zero amount is due to the buyer purchasing in with other parts and I just did a package deal.
FromDescriptionPrice
1uz EngineCrank Sensor
R350​
1uz Engine1uz Alternator
R800​
1uz EnginePower Steering Pump
R800​
1uz EngineExhaust Manifolds
R0​
1uz EngineEngine Mounts
R0​
1uz EngineAdapter Plate
R0​
1uz Engine1uz Front Intake
R2,500​
1uz Engine1uz Injectors
R1,000​
1uz EngineValve Covers
R300​
1uz Engine1uz Sub Assembly
R3,500​
1uz Engine1uz Ring Gear
R450​
1uz EngineEngine Covers
R1,000​
1uz EngineValves
R500​
1uz EngineOil Pump
R600​
1uz EngineOil Filter Housing
R200​
1uz EngineStarter
R1,000​
R300​
1uz EngineTensioner Pulley
R500​
1uz EngineIdler Pulley
R0​
1uz Turbo EnginePerformance Oil Pump
R700​
1uz Turbo EngineBlock
R1,000​
1uz Turbo Engine1uz Intake
R650​
1uz Turbo EngineHydrolic Fan Pump
R100​
1uz Turbo EngineCrank Shaft
R1,200​
1uz Turbo EnginePiston
R100​
1uz Turbo EnginePistons and Rods
R3,500​
1uz Turbo EngineWater pump
R300​
1uz Turbo EngineMainbearings and Keepers
R350​
1uz Turbo EngineIdle Air Control Valve
R0​
1uz Turbo EngineTPS Sensor
R450​
1uz Turbo EngineFront Sump
R500​
1uz Turbo EngineFuel Rails
R300​
1uz Turbo EngineOil Filter Housing
R200​
E87 Aftermarket2xE46 Wheels
R300​
E87Gear Knob and Boot
R500​
E87Gearbox
R0​
E87Propshaft
R0​
E87Shift Linkage
R0​
E87Gearbox Support
R12,000​
E87335i Front Calipers and Disks
R2,500​
E87Boot
R0​
E87Rear Bumper
R0​
E87Tail Lights
R3,500​
E87Petrol used in corolla
R620​
E87Battery Wiring
R0​
E87Key Holder
R600​
E87Rear Door Plastic
R100​
E87Mirrors
R1,500​
E87BMW Locknuts
R450​
E87Fuel Pump
R1,200​
E87Bonnet
R0​
E87Cradle
R0​
E87Headlights
R0​
E87Fenders
R3,250​
E87Cruise Control
R0​
E87Towbar
R2,300​
E87Seats
R3,500​
E87Center Console
R1,200​
E87Battery
R100​
E87Front Bumper
R1,100​
E87FRM Module
R700​
E87Clutch Slave Cylinder
R900​
E87Gear Shift Surround
R0​
E87Trim
R0​
E87Steering Column Covers
R0​
Captain_Stealth
E87 AftermarketPowersteering Cooler
R600​
E87 AftermarketOil Cooler
R1,500​
E87 AftermarketRed Start Button
R0​
E87 AftermarketShifter Bush
R0​
E87 AftermarketB&M Short Shifter
R1,000​
E87 AftermarketBMW Style 264 18" Wheels
R7,500​
E87 AftermarketBMC Air Filter and Shield
R450​
E87 AftermarketE87 Rear Bumper
R600​
E87 AftermarketPower Steering Pipes
R0​
E87 AftermarketFlywheel
R0​
E87 AftermarketClutch
R0​
E87 AftermarketSump
R0​
E87 Aftermarket3.73 Ratio Diff
R2,000​
E87 Aftermarket320D Diff
R0​
E87 AftermarketRacing Diffs LSD Kit
R3,200​
E87 AftermarketH&R Springs
R0​
E87 AftermarketM3 Lower Control Arms
R2,000​
E87 AftermarketKoni Shocks
R4,500​
E87 AftermarketRods
R1,800​
E87 AftermarketCatch Can
R300​
E87 AftermarketSway Bars
R5,000​
E87 AftermarketH7 HID Kit
R400​
E87 AftermarketBurger Morotsport Cabin Filter
R500​
E87 AftermarketMr Turbo - Heat Shields
R800​
E87 AftermarketSeat Harness
R800​
E87 AftermarketRear Subframewith Poly Bushes
R3,500​
E87 AftermarketLSD Diff Oil
R200​
E87 AftermarketSeat Brackets
R500​
E87 AftermarketExhaust
R800​
E87 Aftermarket135i Steering Wheel
R3,300​
E87 AftermarketRadiator
R1,300​
E87 Aftermarket135i Grilles and Bumper plastics
R500​
E87 AftermarketE82 Bumper Headlight Washers
R300​
E87 AftermarketE87 Boot Spoiler
R2,050​
E87 AftermarketCam Seals
R0​
E87 AftermarketCambelt
R0​
E87 AftermarketRear Main Seal
R2,000​
E87 AftermarketDavies Craig Fans
R3,000​
E87 AftermarketE90 Meyle front Arms
R800​
E87 AftermarketHX55
R8,000​
E87 Aftermarket17mm Spacers
R1,000​
E87 AftermarketCambelt Tensioner
R900​
E87 AftermarketCambelt Bearings
R0​
E87 Aftermarket3uz Coils
R0​
E87 AftermarketWaterpump
R0​
E87 AftermarketFront Crank Seal
R3,500​
E87 AftermarketNew Oil filter
R50​
E87 Aftermarket1uz Exhaust Gaskets
R700​
1uz Engine6 x 1uz intake valves
R400​
E87Rear Arms, Hubs, Side Shaft and Brakes
R700​
E873.46 Ratio Diff
R1,800​
1uz EngineSpits Trigger Wheel
R300​
1uz Turbo Engine1 x Piston
R200​
1uz EngineThermostat
R200​
E87Key
R300​
1uz Engine1uz Heater Pipe delete kit
R400​
1uz Turbo Engine1uz thermostat delete kit
R100​
1uz Engine2 x Cylinder Heads
R800​
E87 AftermarketPerformance Diff Cover
R2,000​
E87Drivers door lock actuator
R700​
E87Dashboard
R750​
1uz Turbo Engine2 x Pistons
R300​
E87 AftermarketM3 Steering Rack
R2,000​
1uz EngineSteel Thermostat Housing and Belt
R750​
1uz AftermarketRacing Sump
R3,000​
E87A-Pillar Covers
R400​
1uz Turbo EngineValve Covers
R650​
E87Shell with remaining Parts
R4,000​
Total
R144,570​
Technician
R600​
R1,500​
R0​
R0​
R1,000​
R7,500​
R450​
R600​
R0​
R0​
R0​
E87 AftermarketSump
R0​
R2,000​
R0​
R3,200​
R0​
R2,000​
R4,500​
E87 AftermarketRods
R1,800​
R300​
R5,000​
R400​
R500​
R800​
R800​
R3,500​
R200​
R500​
R800​
R3,300​
R1,300​
R500​
R300​
R2,050​
R0​
R0​
R2,000​
R3,000​
R800​
E87 AftermarketHX55
R8,000​
R1,000​
R900​
R0​
R0​
R0​
R3,500​
R50​
R700​
R400​
R700​
E873.46 Ratio Diff
R1,800​
R300​
R200​
R200​
E87Key
R300​
R400​
R100​
R800​
R2,000​
R700​
E87Dashboard
R750​
R300​
R2,000​
R750​
R3,000​
E87A-Pillar Covers
R400​
R650​
R4,000​
Total
R144,570​
if you mind me asking, over what period did this take?
How long to sell everything.
TBP88
And did you eventually get the dream car!
I hope so, you put a lot of effort into building here, I'm sure you'd do doubly so for your dream car. Good luck going forward!
Captain_Stealth
It took about 1.5years. Lol. Still got some stuff left but I also sold my stuff for cheap the more you want for it the longer you will have it up for sale the shell took me over 1 year to sell
Captain_Stealth
A I wish. Was suppose to be a Porsche. In the mean time I got divorced lol. I paid for a lot of my ex’s debts seems she had other plans
Been looking at a few options
2008 Porsche Cayman
2016 C63
2013 opel Astra opc
E92/3 335i
E90 330d
E46 330d
Golf 7 R
Gold 7 gti
Audi S3
First Audi rs3
M6 v10
Lumina ss
One idea that I have been playing with for now is a full spec E55 amg w211. It came with a 5.5l supercharged v8. It seems it is possible to add good power with bolt-ons. Also it is possible to do a manual swap and with a proper lsd. I recon it will be a beast. Rumours is you can get it to a 1000nm reliable not sure thou lol
Dewald Basson
Cap, sorry to see it didn't turn out as planned.
Best of luck with everything, stay strong.
Sent from my SM-A315F using Tapatalk
