Gavsadler's 2011 E90 M3 Sedan M-DCT
gavsadler
Time to do some updates to bring things current :smilebounce:
Going back to mid-june, here's some pics the day I collected. Late afternoon shadows don't do much justice to the lines and black bits on the car (which is sucky IMO)
Then on day 2 of ownership, whilst leaving the ignition on to check service schedules, any faults and so on, I was greeted with a low battery warning. Subsequent drives also showed that if leaving the ignition on for approx. 1min, then the warning pops up, and the car automatically shuts down after approx. 2mins. Even connecting the trickle charger for 1.5 days solid didn't change this, so I suspect the battery (almost 3 years old) is not so lekker due to the electronics in the car, and the fact that it stood for fairly long periods of time between drives.
Here's a video of the warning (1min mark), and when the car automatically shuts down after 2mins:
[video=youtube]
So, whilst the car was connected to the trickle charger:
I decided to scratch around a little bit under the bonnet:
BMC drop-in filter installed, no complaints from my side:
Here's the inlet from the filter to the tube which leads to the intake plenum, rectangular in shape, with some odd curves in places (on my long-term list to do a few changes here):
I also sourced some spare wheel nuts which I chemically cleaned, with the plans to paint them black:
And to end off: a night shot of the instrument cluster, I am quite fond of the lighting (and other lighting on the car in general):
Here's a quick iPhone video of the cold start and idle:
[video=youtube]
And here's a small 2nd gear squirt on a slippery downhill:
[video=youtube]
The first tank I drove very carefully on purpose, to see what somewhat hopeful fuel consumption figure I can get in future. This was probably my typical driving style, and included about 60% highway and 40% town driving. What's somewhat alarming at first is when the fuel reserve warning comes on with 1/4 tank still to go!
First tank fuel consumption:
In the car's previous life, it has had some cosmetic work done. Overall the end-result is positive, although there are clear signs where shortcuts were taken / where whoever worked on the car was less talented in strip and assembly than what is desired (more about this later on).
The 2 front plastic jack blocks were missing, so I organised some through Deago@ABM (thanks mate).
The location where the jack blocks clip into the chassis:
Some leftovers of one of the missing jack blocks:
New jack blocks installed, and testing out with the proper rubber inserts for use with a trolley jack etc:
Whilst at ABM, I also acquired a new set of locking wheel bolts (for preservation of my future plans):
Moving to the back of the car, there were also some minor niggles which were troubling my mild OCD.
Missing cover for one of the screws holding on the bumper skin:
And the bolts to hold the bootlid onto the boot hinges were faaar from OEM:
So in one of my trips to a local scrappy, I sourced a replacement cover and some white OEM bolts:
In doing this, I also did some minor adjustments to the bootlid to get it to align a little better to the rear quarter panels, lights and bumper. I still need to touch up on the bolts where some paint chipped off, but will get to that soon.
Oh, I also forgot to add, about a week after getting the car, I went to visit Gert from OBDWorx to cut and code a new spare key for the car (only had 1 key at time of purchase).
Thanks to Gert for the hospitality and great service :thumbs:
Moving back to the front of the car, as mentioned earlier, I have not been such a fan of all the black bits on the car. This includes the front splitters. For sure it looks aggressive and intimidating and racey, but quite frankly, it doesn't really fit with my personality in that I like to keep a relatively low profile.
So I decided to get busy removing them. This was before removal:
And after removing one side:
And after removing both sides:
What's also good to know is that these are the genuine OEM Performance bits:
Mixed emotions as to why the beautiful carbon fibre was painted over, but anyway. (I stand to be corrected in case these were wrapped, I honestly didn't spend too much time looking at them further)
I actually prefer the clean front-end. To me, the front bumper looks wider now that the lower white sections are exposed again. That being said, these will go into a box for safe-keeping, and maybe at some point in the future I will try them out again. I've seen some other ideas too which may work well, but all in good time...
Whilst scratching under the front of the bumper, I garnered a look at the splash tray, which has also had a few beatings in it's life, and some attempted fixes:
This is also on my to-do list at some point to sort out properly, which most likely means a replacement part.
My curiosity also extended to the gloss black mirror caps, so I pulled these off, and also pleased to report that they are OEM carbon fibre bits. I think they have been painted gloss black though (unless also wrapped? - TBC).
StrollingCoal
Damn :inlove: I also prefer the cleaner look sans the carbon bits
Just for interest sake what did you use to clean off the black sticky stuff? I recently had to remove two way tape of my bumper and I found that windowlene worked really well.
Fordkoppie
The first few pictures on the top of this page is exactly why I despise black wheels. It looks like a BMW test model.:roflol:
Well done on getting things sorted, and acquiring what seems to be a very nice car. And I agree the front looks way better without the splitters
gavsadler
Whilst all the above was happening, I secretly had something else in the works as well. One of my biggest risks and causes of stress I've committed to in a long time. Sitting on eggs for 29 days, wondering if the deal would be successful is not good for one's health, and to say I was losing sleep about things is an understatement.
Shortly after getting the car, plans were set in motion for a wheel change. The rims fitted to the car are Style 359 Competition reps, painted in matt black. In keeping with my intentions to de-black the car a bit, I did consider getting these wheels refurbished and painted back to hyper silver.
Sadly though, I have a disease whereby I gravitate to all things OEM, and I knew that I would never be fully satisfied knowing that there are awesome OEM 359s out there. It also didn’t help that the other cars I had looked at around the same time were also white, and Competition models with the 359s as standard, so I knew exactly how the car would look in the flesh. The bug had bitten, the itch had started….
Looking locally, there were a couple of sets of Style 219s and 220s, but no 359s. Those in the trade also mentioned that they are pretty much hen's teeth to find used, if at all (given that they only came on 2 models, the E82 1M and the 2009-2012 M3 Competition)
So I extended my search globally, knowing that should I happen to find a set, I will haemorrhage on the shipping costs, not to mention import duties and taxes. I ended up chatting with a few people in both the States and in the UK, but various factors meant that it was difficult to close out a deal.
Then, a couple of weeks later, I managed to strike a deal with a guy all the way in San Francisco, California, and so a set of 359s began the 17,500km journey to South Africa. The wheels were packaged up and sent via road freight from California to New York, and from there via Air Freight to SA. Thankfully, the company I use for shipping stuff from overseas was kind enough to offer me quite a significant discount on the normal fees, which is what made the transaction somewhat feasible.
Fast forward 29 days from when we did the deal, and early in August, a couple of big boxes arrived at my door:
Happy happy happy! And even more so - relief! Everything had worked out just fine. Thanks to the seller in CA for being honest and truthful about everything, and for also answering all my questions and going out of his way to assist a fellow enthusiast from the other side of the world.
During my overseas shopping, I also sourced some other goodies.
A set of brand new OEM carbon fibre mirror covers came up for sale at a reasonable price, so decided to splurge on these too. (This was also before I discovered that the car has carbon fibre covers fitted currently, even though they are gloss black. These are still packed away nicely, will see if I end up fitting them, or if my quest to make things plain Jane white will continue...
I also ended up purchasing a replacement gear kit for the throttle body actuators. I had done plenty of enquiries with fellow enthusiasts, reading forum threads and watching youtube videos during my nights of insomnia. There are a few different kits out there, some are the gears only, and other sets like these include a replacement shaft. More details on this in a future update...
So, after unpacking all the goodies, I decided to give the wheels a quick clean up, and get them ready to have the tyres swapped across. I finished well after sunset, but couldn't resist a pic with them all shiny:
I arranged with my brother-in-law to get the tyres swapped over for me. This went smoothly, and the new rims do not have any cracks or buckles. That's great news for me, meaning I don't have to do anything to them right now. There is some curb rash and some scratches on the rims here and there, but nothing too bad that can't wait for a bit. Most likely when these tyres are KO, I'll get the wheels refurbished before fitting new tyres.
So the M was pulled into my backyard service bay, as there were a few things to attend to.
Here's some pics when we jacked it up to put it on trestles. Notice how stiff the car is. Jacking up at either the front or the back lifts the whole side of the car:
And then after swapping over the tyres (and doing some other maintenance items), the new wheels went on, and here's some sneak pics of the final product (still dusty and bad lighting):
I am very pleased with the outcome! Seeing it done and dusted makes the stress and worry worth it.
Time to geek out again with some specs on the wheels:
359 Reps:
Front = 8.5J x19 et34
Rear = 9.5J x19 et37
359 OEM:
Front = 9J x 19 et31
Rear = 10J x 19 et25
So in summary, the OEM wheels are wider than the reps, and have a lower offset = more concave = more yum yum. While we were joking around, we were debating whether its more like a J Lo rear end, or a Mariah Carey, but I guess that comes down to personal preference (I'm in the J Lo corner lol)
More updates coming soon, just need to sort through some more pics...
Holleeeee SHEEEET.
Gav, very nice change there, and i think the work youve done is amazing.
the colour change ont he wheels really made a massive difference,
i was very pro black wheels on any car, and think as ive grown older the OEM look is best.
Phat01
Wow it just gets better and better as you restore it back to its former factory glory! Love the attention to detail!
UpNcOmiNg!
Events Organiser
:praise:
Good Lord that is perfect! :inlove:
Once she gets dropped and spaced onto those wheels it will be pure sex!!!
Well damn done, that looks so proper already. The work you have done has really brought the car back, it is millions of times better already!
VinceM
Man,
This car looks different. its awesome. well done
You and I, as the kids would say, we are in the same whatsapp group. OEM all the way.
gavsadler
Thanks for all the compliments guys, so far it's been quite fun.
I used a combination of finger nails, and parrafin I think, took a while to get it off but didn't want to get too aggressive with rubbing and harsh chemicals which may damage the paint etc. (Mental note made of Windowlene...).
While my brother-in-law was busy cleaning off the hubs to fit the new rims, he noticed a few funnies. There were a couple of bolts and screws missing from the fender liners, bumper and splash tray. Also, once the said missing screws were fitted, the bumper was still a bit droopy in the front, almost like it was only hanging on the top screws. So we made the call to remove the splash tray and fender liners to see what's what.
I alluded to it in an earlier post, where whoever worked on the car did a good job visually, but in terms of reassembly of the parts, shortcuts were taken. Once the fender liners were off, we noticed that the LHS bracket which stabilises the bumper behind the stiffener was only (barely) fastened on the chassis side, and not attached to the bumper at all. Moving to the RHS of the car, the transmission oil cooler was also being held on with 2 of the 4 required bolts, so in effect it was flapping around like an elephants ear.
So... after a quick chat, we decided to fix things properly....
Time to make lots of BMW puzzle pieces:
The car was also full of residual 'white water' dribbles and stains all over the black stuff (from prior spray work and cleaning), so in the pics above, all this mess was cleaned off.
Once the bumper was off, we attended to the loose bracket and secured the transmission oil cooler. Then we noticed as well that the RHS headlight was only attached with 2 of 4 screws. So we sorted this out as well.
2 afternoon's worth of work later and everything was sorted and put back together. It's just annoying how so much stuff was not attached properly. Surely when these chaps clean up after a job and find spare parts they must scratch their heads a bit??? Maybe I'm expecting too much.
