///Herbie
I've had mine done by Mosports Performance aka MPD in cpt.May i ask who did the software for you?
Did the swirl flaps too
Sent from my SM-G990E using Tapatalk
How is your gearbox responding to this? No shudder at low rpms?I've gone that route.
Stage 1 + egr delete + decat (hollowed out oem housing)
Night and day difference.
None at all sir. Car gear changes are same as they were before.How is your gearbox responding to this? No shudder at low rpms?
Why would it shudder with a tune?i get more power and torque but it should not shudderHow is your gearbox responding to this? No shudder at low rpms?
The ZF6 on the E90 LCI 320d is relatively safe to put 450nm through; hence my question. Stage 1 with downpipe/decat should make about 420-450nm. A lot of cases where stage 1/2 20d owners claim they feel a shudder/vibration when taking off or accelerating from low rpms due to high torque.Why would it shudder with a tune?i get more power and torque but it should not shudder
Sent from my SM-G998B using Tapatalk
So mine had the shudder and my gearbox broke...but we pushed the car over the 450wnm threshold and it gave way. thankfully...i got it done and a new gearbox was fitted. So it is very possible and mine was still not even 60000km when i broke it.The ZF6 on the E90 LCI 320d is relatively safe to put 450nm through; hence my question. Stage 1 with downpipe/decat should make about 420-450nm. A lot of cases where stage 1/2 20d owners claim they feel a shudder/vibration when taking off or accelerating from low rpms due to high torque.
Yes EGR delete was done. My thoughts exactly on the downpipe. ThanksIf you already done the decat you can leave it as such and perhaps do the downpipe later on. Did you also delete the EGR?
Some cars just respond better to even 'mild tunes' as in my case. When logging I requested to stay in safe perimeters as per 'stage 1', but gained 100nm and 20kw.So mine had the shudder and my gearbox broke...but we pushed the car over the 450wnm threshold and it gave way. thankfully...i got it done and a new gearbox was fitted. So it is very possible and mine was still not even 60000km when i broke it.
Gearbox giving it at 60 000km. That's odd. I sold my E82 120d with 450nm on around 212 000km almost 2 years ago. Owner did stage 2 with cooler and it pushes close to 500nm. Gearbox still keeps up.So mine had the shudder and my gearbox broke...but we pushed the car over the 450wnm threshold and it gave way. thankfully...i got it done and a new gearbox was fitted. So it is very possible and mine was still not even 60000km when i broke it.
Ja we pushed it very hard, the car just had the file on then DP and file and we pushed it right till the max....hence I say we BROKE it...was no fault at all of the car or its reliability. Even after the gearbox was replaced a milder map on it but it still performed so well. Once of the most solid cars i had bar breaking it lolGearbox giving it at 60 000km. That's odd. I sold my E82 120d with 450nm on around 212 000km almost 2 years ago. Owner did stage 2 with cooler and it pushes close to 500nm. Gearbox still keeps up.
Did you have Xhp Stage 3 on the old box? Does increasing the torque limiters catalyse wear? And how often did you launchš«£?Ja we pushed it very hard, the car just had the file on then DP and file and we pushed it right till the max....hence I say we BROKE it...was no fault at all of the car or its reliability. Even after the gearbox was replaced a milder map on it but it still performed so well. Once of the most solid cars i had bar breaking it lol
Nope, I had an Alpine tune...wasn't xHP but this was also 10 years ago.Did you have Xhp Stage 3 on the old box? Does increasing the torque limiters catalyse wear? And how often did you launchš«£?
