Nikhil
Interesting outcome, so all its doing is making a little more than stock power at the wheels? Sav’s cars all run locked Vanos, I went for a drive in an E36 M3 Turbo recently which makes 300wkw at kar and the power band is identical, dead till about 3000rpm 3500 you can feel something happening and 4000rpm all hell breaks loose at 0,8bar boost.
My thinking is going with a slightly smaller exhaust housing and bigger injector’s turn up the boost to 0.8bar and she should be happier. I see the rev limit is also dropped to 7000rpm so even if power drops from 6500 with a smaller exhaust you still have a more “Usable” power band.
:rollsmile:
:rollsmile:
