Hi guys,
My '95 E34 540I is idling like it's having a tantric orgasm and it's running exceedingly rich. I checked the single vacuum hose at the rear of the intake manifold and the other blanked-off hoses...all are OK. I also sprayed water over them and the intake hoses to check for airleaks. Nothing. I don't hear any slurping noises and if I remove the dip-stick or oil-filler, there is little change in the lumpy-idle.
Next step seems to be the PCV. It seems to be accessible if I remove the whole rear cover of the manifold that is secured by 7 Torgue-screws. Is this removal for access to the PCV feasible? (without removing the whole manifold etc) and if so what do I need to order from the stealer, in other words, where exactly is the PCV?
A useful address that shows the whole caboodle.
http://www.realoem.com/bmw/showparts.do?...g=11&fg=40
