Jive_E46
Some home DIY...
Fitted a new belt tensioner and idler pulley. Didn’t bother with the AC pulley and tensioner, maybe another time. All sourced from Imcomex
Part numbers:
- Belt tensioner: 11287838797 (INA)
- Idler Pulley: 11287841228 (Topran)
It was a like for like swap. I thought I had the old spring based tensioner but it was the modern piston based tensioner, OEM part that was on its way out.
The bolt that turns clockwise to remove the serpentine belt was absolutely stripped from previous mechs and I DEFINITELY made it worse by prying a torx 45 in there
(It came off eventually and never went back on)
The process was pretty simple, took my time and made sure everything was perfect before turning her on again.
She’s running 100% after the install and loves the limiter even more IMO
Next up is the noisy and inaccurate fuel pump.
Part numbers:
