Burg, let me quote something Peter taught me over the last year I have spent watching him work on my and many other cars.
"The wise man is only wise because of the many fuck ups he made in his past."
You can only learn, and grow, from making mistakes. No one is perfect. And the best thing about this build, you and I learn't a lot from it.
You understand the complexity of the build, and the fact that this supercharger build is almost completely custom, only shows that this was not as easy as slapping a charger in and calling it a day, as we soon discovered.
Let me clear this up for everyone on the forum, this kit needed a lot of fabrication. It was not a simple bolt on kit that you can buy from VF or AA or ESS etc. Yes, it was originally a VF engineering kit, but I wanted a Blow off Valve and Alpha N software, which VF do not do (also, VF's tuning is apparently left much to be desired and many VF members have since moved over to an evolve Alpha N tune). That mean't we needed to change the intake manifold, the MAF sensor needed to be replaced with a air temp sensor, which needed to be relocated into the intake manifold and upstream from the supercharger, as opposed to being before the supercharger. The recirculation valve needed to be blocked off from the supercharger intake, an idler pulley needed to be fabricated, the sump oil return line needed to be blocked off, new vacuum lines needed to run from the emissions rail to the blow off valve, a new idle control pipe needed to be fabricated, an oil catch can needed to be installed with a line running from the tappet cover to the oil catch can and the brake booster needed to be re-installed into the supercharger intake pipe. Also, the injectors used are 10mm taller than OEM. So a new injector rail bracket needed to be made as well as fuel line extender needed to be used. None of these fabrications are done by VF. Active Autowerke does most of these mods to their kit, so we picked some ideas from some of the guys running those kits, but I am pretty certain this is one of the first, if not the first, Active Autowerke / VF engineering Hybrid supercharger kit. The idea behind this build was to take the best of both kits and make it work. The super efficient and large V3 supercharger from the VF kit mixed with the design of Active Autowerke intake to work the Alpha N tune file provided by Project Shift.
None of the above mentioned things that were fabricated came with the kit. Burg did his best to make things work, and whilst most of these things were temporary, in the end, the build just needed Peter's attention to detail to give it that one last touch of perfection.
I take my hat off to Peter and Burg for meeting up and going over the fixes Peter made to the build. As much as Peter swore from under the car, I could see today that he was happy to show Burg the small details that were required to give it that lasting touch of awesomeness.
So... the car is supercharged. The fuel rail is secured and new injectors are in. Peter should have the intake pipes installed today, and tomorrow the car can go for AFR's and logging so a custom tune file can be made for her.
As I mentioned, this kit is completely custom, so I have no idea what will happen after we do AFR's. The charger has been sitting for 2 years now, I just hope the bearings inside are ok. The worst thing that could happen now is that the supercharger is kaput and we went through all of this for nothing.
LOL. ok, enough negativity. Till the next update...
Jezebel returns.
