Hmmm... interesting. Looks very complicated tho.
And... I want to run an Alpha N tune... I'm guessing this AEM ECU can do pretty much everything.
That being said, I have a uni Q Dastek kit/system from my old supercharged 323i. Wasn't planning on using it on my M3, but what are the possibilities of getting Ross @ RBTS to tune the car with the uni Q if all else fails?
At the moment I will be using an Alpha N tune that Burgy has sourced for me. This is a very good Alpha N tune, as some of you will remember Alain's e46 M3 that had a custom supercharger kit installed by some shop in Durban. Long story Short -- The original guys that built the car, couldn't tune it to save their lives. THe car didn't run, idle surged, car was undrivable. Just did not work. Alain can confirm this. Burgy installed the Alpha N file that Project Shift sells and this car is now running smooth as butter and did 267wkw on a base map. It is running a small rotex charger, running a very restrictive 6psi, as the plumbing really needs to be redesigned. So I know the file works. But thanks for the input, I shall keep the options open.
Anyway, Gizmo... I'll come by some time and check out those cat foolers and pick your brain regarding these O2 sensors and Exhaust sensors and how to eradicate the errors.
