Cabin noise from door seal rubbers
DeanoBlado
Hi guys
My car started with this issue out of nowhere, while driving i can hear squeaking noises on the door frames almost like the door rubbers rubbing against the door frame. very annoying. ANy idea what i can use or why its doing this?
found this on the web. exactly what is happening on mine. alos have the sport-line trim.
http://www.m3post.com/forums/showthread.php?t=1017134
CarlosR
DeanoBlado said:
Hi guys
I have the same issue!
The article seems to list 3M squeak reduction tape and or a lubricant called Krytox.
No sure where to get either though. Let me know if you find a place!
FerdiBotha
This is an issue with many BMW models.
My E90 and both my parents' F30's do the same.
All these vehicles have gloss black trim around the doors and I have been told that is the cause of the squeek.
The F30's got the squeek sorted at Zambezi auto under motorplan by applying the 3M tape.
I'm yet to sort out the issue on my E90 though:hammerhead:
FerdiBotha
DeanoBlado said:
My car is still on MP so i will book it in to get sorted, hopefully they know about it.
I'm sure they will know of it. I spoke to a guy from BMW Rosslyn plant and he told me about the fix and that it's a cheaper solution than replacing all the door trim pieces.
If you don't come right at your dealer, take it to Zambezi auto (if possible):coolShake:
E-Male
Jees...I have the same problem with my e90 and it's been driving me bonkers! Any idea where to get the tape from in jhb?
FerdiBotha
I would love to know as well:smashScreen:
RajivR
Have the same issue on my F30.
Applied Wurth Gummi Pfledge (purchased from Wruth on Malibongwe, approx. R130 for an aerosol) and it is dead quiet. Application method used: Clean the hard rubber above the windows with Shield Heavy duty Vinyl & Rubber Cleaner then spray Gummi Pfledge directly onto this rubber.
Problem is...the squeaks return after a few months and I have to reapply.
Would really love to know where I can get the 3M tape here in JHB:ty:
E-Male
Thanks for the info bud!
Centrino
Hi.
I have a 2016 F30 BMW and have been battling with this issue as well. My one rear door doesn't stop creaking. I've been to 4 dealers in the JHB area and 3 times to the same dealer. Have had tape applied, new rubbers installed and still the same problem.
I've actually given up.:smashScreen:
I just turn up the music and drive.
Danielb1
Hi Rajiv, where did you buy the Pfledge from? i am in Durban and would like to know
FerdiBotha
It says in his post - Wurth on Malibongwe drive.
RajivR
Howsit Bro, I see Wurth is in Pinetown. Got this off :google:
Address: 139 Josiah Gumede Rd, Pinetown, Durban, 3600
Phone: 031 701 6900
Perhaps give them a call :thumbsup:
Danielb1
Hi Boss. I called them and they have the 300ml spray for R133. The rep will deliver a can to me Monday. Thanks for the assistance
Sent from my LG-H815 using Tapatalk
bobbychoo
wouldnt a squeak mean that the door is loose? Like the nuts that attach it to the frame. I dont have that issue on my car But that is something i would check, i suppose.
DeanoBlado
So my noise has disappeared, been more than three weeks now, all i did was just give it a good clean.
No special anything used.
DeanoBlado
My car went in for a service yesterday at BMW and i told them about this noise. the SA said that they know about this issue for the F30 but not the E90.
When i went to pickup my car he said they did look at the rubbers. On invoice it states, replaced and refitted rubbers or something to that effect. lubricant was also applied
When i close my door now, it has that brand new solid sound to it. the door closes without any hassle or bang. Hoping the issue is now sorted.
Danielb1
Hi Guys. i have tried the Gummi Pfledge spray. and it works like a charm.
thanks to this post i have resolved squeaky issues.
thanks
Daniel
