moranor@axis said:that ecs tool looks real flimsy i wonder how long it will last...
i just use the old pad and a G clamp to push the piston in...
frikkieh said:moranor@axis said:that ecs tool looks real flimsy i wonder how long it will last...
I just used my two thumbs to push the caliper back.:thumbs: in rare cases a G-clamp is required.
abmi0000 said:Frikkie must have strong thumbs!![]()
frikkieh said:abmi0000 said:Frikkie must have strong thumbs!![]()
:thumbsup: :rollsmile:
Sankekur said:I would be interested to hear what your experience with these pads are cois (you also like using your brakes), cause I had them on the 330i for a while, and I have to say I was happy for a while, then they just became crap almost overnight. The bite from my brakes felt worse than the brakes on the 318i, that had the exact same pads in :thinking:
SP33DYV said:
Midas sells something similar, but looks better quality wise. Used one last week when helping a friend change his discs and pads on his Merc. The screwdriver between the disc and old pad trick is a lot quicker though.KSINGH said:that tool looks great
any idea on price otherwise will search
KSINGH said:Cois, I have used Bilsteins from BEMOW's in the past. I suggest you change them around 50% life to avoid inferior performance and uneven wear.
Unless if these from Goldwagon are better quality.
The ones I had wore so unevenly my sensor did not go off but they were scoring my discs on the corners :argh:
i will pop into Midas and check em out.
how do you get the screwdriver between the pad and disc without damaging the disc?
abmi0000 said:The disc is extremely strong though and the piston doesn't usually require that much force. I generally open the fluid bottle cap to reduce the pressure.
outlaw335 said:Guys on the topic of discs,where can i find for an e90 ie besides the dealership?
Coisman said:Ok, got the pads and sensor at goldwagen for R460 :rollsmile:
abmi0000 said:outlaw335 said:Guys on the topic of discs,where can i find for an e90 ie besides the dealership?
what E90?
