Hi,
update on my 135i Build
it saddens to say the car is dead,
After getting good numbers on pump we changed over to E70 and logging started, it was going well and we got to +- 28psi and then I noticed coolant coming out of water bottle.
I bought new bottle and cap thinking that was the issue unfortunately is was not.
I then started to research and found numerous threads on several forums with similar issues and 90% of them was due to incorrect ARP head studs being used, most sets sold from various venders in the USA are for Chrysler 2.2 (They are 12.5mm too short).
I then thought that was the problem, I ordered a new set (14 studs 11mm) that meant I would need to remove head and drill and tap the 4 outer holes to fit the 11mm bolts.
We removed the head and to my dismay found three cylinders cracked.
Two of the top N54 engine builders in the states told me, You never re-bore/hone a N54 block without close decking if you want High Boost targets.
It is recommended to re-sleeve rather than re-bore
I cannot find a local engineering shop that can re-sleeve and close deck, well one that has done it successfully.
The build has been put on hold for the time being with the following options:
1) Sell rolling Chassis, the add is already on Gumtree (No Engine, gear box, gear lever or anything to do with Motor)
2) Once Chassis is sold break the rest of the motor and sell what I can (Block is scrap and cannot be fixed)
3) Rebuild motor (+- R80K Bring prepped block, closed decked with pistons fitted from US) use all my parts but then car will be capable of 900whp
To be honest I was penny wise and pound foolish, I wanted to sleeve and deck last year but was convinced it was not needed.
This car has had some serious money put into it and right now I don't have more to continue.
The last three and half months have been very bitter and right now I just want the car gone, who knows my mind might change over time.
Thanks for following to all that did.
