Dirtydeedsman said:Iceman12596 said:Dirtydeedsman said:Thank you very much Gentleman
@Iceman12596 and @subloaded How do you connect your mobile device to the car's bluetooth? I can't figure it out at all. Managed to get to the Bluetooth PIN so I am guessing that is something..
Default pin is 0000 should be called Car BT or something long those lines
Finally figured it out, it was changed from those defaults to another random number. Now I have also doscovered that it only does phone calls and can't stream music from my phone... think I will just get an SD card to sort that problem out
r0ckf1re said:Congrats, I had a 2013 A4 as well, nice car, very comfy.
The bluetooth connection was straight forward, the pin is either 0000 or 1234. It does show up during connection and you would just need to confirm.
I had the car for 3-4 years and no oil issues. Pretty solid car, no rattles etc
I had a manual, went well, decent power (especially mapped). Just don't try and launch it or change too hard :fencelook:
Wanted a manual as well but this one just spoke to me in a way I can't even explain. Fingers crossed I get no issues. Does take some time to get used to these CVT boxes because unlike the stronic. This feels like its always in neutral and when you pull off from a stop I have to let it crawl before I put my foot on the accelerator otherwise it builds revs then gives you like a 3 -5 seconds delay before it starts moving.
MR_Y said:My 2010 B8 1.8T manual was better built and better finished than my 2017 F30.
However, I don't miss the oil consumption issue (your B8.5 should be fine).
Coolant bottle cracks seem to be common on this model (a few mates had this issue), so rather check coolant regularly.
No other big issues really.
Just check the timing chain and CVT at the next service.
The CVT does drone a bit, that is why I chose the manual back in 2010. But, if you adjust your driving style, it should be a comfortable cruiser.
Got it booked for next week at a mechanic just to make sure all is good. They serviced the car before I picked it up but knowing stealerships they probably didn't change filters
FILV said:Congrats!
Im also looking for one of these.
These have the Gen 3 1.8tfsi engine, which is actually the smae engine as the Facelift polo GTI. very reliable and tuneable engines.
Manual even better, no need to worry about the very unreliable Multitronic boxes.
did anyone find the clutch pedal to close the foot rest? i kept cliping it with every time i pushed in the clutch.
super quiet ride, the audio system is very good.
many happy miles :bravo:
It is quit nippy for its size when I put it in S or Manual... The audio is amazing. I have AUDI concert, has many many speakers and options to make it even louder. Makes some descent bass too
yeah its a fantastic audio system. The Concert is a 10 speaker system, so either than a split system in each door, you actually have a speaker in the center of your dash, and if you look inside your boot, and look up, you will see an 8 inch sub on the parcel shelf. it comes with a 180watt amp if im correct.
enjoy it!
