2000 Alpine White III Z3 Mcoupe
Gizmo
Banned
Made another pass on the chassis clean, fuel/brake lines looking better.
Heat shield also looking better.
The remains of the dirt is hard as varnish, I will need someone a lot stronger than prepsol and elbow grease!
Auditor
Fantastic documentation of all the work performed!
It is completely clear that you have lavished attention onto this car like it was one of your own. Clearly a sign that in an age of mediocrity and greed, pockets of excellence and pride in one's work still exist.
Exceptionally well done Gizmo!
Gizmo
Banned
She will be mine one day, just got to find a clean ACS Z3M to replace it... :fencelook:
Gizmo
Banned
OEM fuel filter sourced.
Tagged the mileage and date with engraver.
Installed.
Remove and strip down old shocks.
Clean the springs, pads and hats and re-assemble onto the new shocks.
Remove old front control arms and bushes, replace with meyle HD ones.
Powerflex 3.0lt M3 front control arm bushes to be installed.
Tie-rod ends being replaced by new meyle units.
Front suspension cleaned and finished, covers going back on after cleaning.
Boot interior re-installed.
Oil service.
Sump plug had been tightened by Thor himself!
Jeremy
The attention to detail of your work is amazing Giz, very hard to find anyone with such a passion for what they do, well done
Gizmo
Banned
OEM oil filter going in.
Upon re-installation of the sump plug, it went soft way before 25nm had been reached.
Replacement sump plug found.
Sump plug cover refitted.
New oil going in.
Service and brake fluid lights to be reset.
R5 resetting tool, well used!
Reset done.
Fordkoppie
Thank goodness you poured in the right viscosity, unlike all the other sheep that simply put in TWS 10W60 *insert ; Glue*
pimpassdaddy
This is the EXACT car that is missing in my collection. Colour and everything. Put in a good word for me please :rollsmile:
I would buy it in a heartbeat!!!
Gizmo
Banned
Brake fluid flush, vacuum out the old stuff.
Old fluid looks rather dirty, seen much worse though, probably the most neglected fluid in a vehicle from my experience.
New brake fluid in.
Vacuum all the old fluid out the calipers and lines.
Top up the reservoir afterwards.
Adjust the handbrake the correct way.
Looking for reasons for the airbag light, pulled both seats out to inspect the wiring and seat belt pre-tensioners. Found someone had a go at it before me.
I cut off that maroon plug as I found the pins were damaged, I soldered a new plug onto the wiring and that cured the driver's side pre-tensioner fault. Passenger side I could only find the seat occupancy was disconnected, plugged that back in and that fault went away. Couldn't find the passenger side pre-tensioner issue though, it had connectivity but the fault still persists.
Driver's airbag fault was still coming up so I wanted to check for connectivity, it was connected. Hmm...still the original airbag from 1999. Will get this sorted at a later date.
To finish off the work, gave the engine bay a clean.
Gave the car a wash.
...And ready for collection.
I asked my good friend Bradley with the red touring to follow me to Elton's house so I could drop off the car and give her one last ride, the handling is absolutely perfect! The car sits on the road like its running on rails! I thought the powerflex bushes would make the car feel hard and unforgiving but that is most certainly not the case as those brilliant Bilstein shocks soak up all the harsh bumps in the road and the two go hand-in-hand like bread and butter! That final drive only made my lust for this car so much more, I got to drive my dream car and it has exceeded my expectations in every way! I must give a big shout out to Elton for giving me the opportunity to work on and drive my dream car, you sir are my HERO!!!:blowheart:
:ty::ty::ty:
GoCart
Great work Gizmo, I much impressed, and happy that I have first option on buying the car back from Elton when he decides to one day sell it...
