Ga-3M in for vanos rattle clearances
Peter@AEW
Gareth has dropped his car for the normal M3 stuff to be done to it.
We will start on it tomorrow and pics soon thereafter
Peter@AEW
Theo D said:
How come you are the only one that cannot see the pics?
No one else is complaining?
Probably you have a virus that does not allow you to see the pics I have posted? :dunno:
Theo D
Nothing wrong with my eyesight thanks, and I wasn't complaining either.
Peter@AEW
Car is on 130k and is mechanically sound with strong compression (hot 160-165) all cylinders.
No stress cracks visible on boot floor or under seat or spring pads.
Typical of MP the motor has a honey colour to it but it cleaned very quickly once detergents were applied.
So here come the pics:
Pay particular attention to the above pic and you will notice that the both leading and trailing tabs on the exhaust hub are highly polished.
This is due to seals not keeping pressure and the hub "oscillates" for want of a better word.....if any of you can think of a better word please let me know I have racked my brain looking for the correct descriptor.
This is what the oil pump disc looks like with the tabs "oscillating/rocking" back and forth. This eventually leads to the hubs braking and the consequences are catastrophic
I tried to get a good representation of oil seepage past the seals.
The following is a series of pics of the inlet can piston with seepage visible.
Notice how this side has a clean upper area which implies oil seepage.
and this is cleaned and ready for seals.
New seals fitted compare to the pic above
Exhaust piston shows a lot more discolouration.
Cleaned and fitted with new seals
The magnifying glass I use to verify the integrity of the seals once inserted and extracted from their chambers.
small precaution to make sure that I have not nicked an edge on the seals whilst inserting them.
Bolts were checked for tightness...all good
All good so hub was cleaned and replaced
Rattle kit for inlet cam
Rayzor
Such attention to detail, your workmanship is of the highest standards :praise:
Im sure Gareth is over the moon :rollsmile:
Nikhil
I guess we will be seeing this car shortly to test its newly found power :rollsmile:
Kimeran
Damn....I wanna buy an E46 M just so you guys can do this!! :roflol:
Gareth, we need to see this car in action once you get it back!
Peter@AEW
Just started it now and it sounds glorious.
I rate this engine highly....Gareth has done a good deal in getting this car
I shall take it for a drive (with Gareth) just now around our test circuit and see how it performs.
Last time around the test track it battled to deliver in 6th gear at 1000rpm...I am positive that this time round it will deliver.
A sweet and smooth sounding s54 is absolute panacea.
I know that BMW produces very quick cars nowadays however they lack the soul of the M motors.......I guess I am old school.
Ga-3M
First off a big thank you to Peter and Alex for the work done, as everybody has seen and commented already, your work is of the highest quality and I really appreciate the extra effort and care taken!:praise: A second thank you to Peter for keeping me up to date with every stage of the work done!:thumbs:
I'll be collecting the car later today and can't wait to drive it!!:rollsmile:
